Wider Tires on 997.2 C2 (base)
3rd Gear
Greetings,
I happened across a set of 4 OZ racing wheels (front: 11 x 18, rear: 12 x 18) for sale.
My first question: will this cause problems with the limited slip differential?
Wll they fit the narrow body? What spacers (if any) would be needed?
Also, any negative effect on handling or anything else to watch out for (wheel rubbing)?
Cheers,
Doug
Cheers,
Doug
You've made a common mistake, posting something about a non-911 in the 911 forum. I'm referring to the sequence 911, 964, 993, 996, 997, 991. You can blame Porsche for this confusing business.
