Replacing fan housing - help!
Team Owner
I was able to see where the interference was happening on the bottom. I filed out (ever so slightly) the 'offending' area. I can now get it to seat all the way against the engine casing.... but only without the air diflector installed. Once I install that, the air 'fins' push against the top engine housing and no longer allow the bottom of the fan housing to seat properly. So now I'll need to file down the fins a tad. What a PITA.
You're correct Amber Gramps... the Vertex 'upgraded' aluminum housing is VERY poorly designed. And for the price I paid they will be getting an earful from me. If my original housing wasn't so badly cracked I would re-install it and send back the Vertex version.
I've definitely learned a bit more about Porsche engineering and a lot more about my patience (or lack there-of) with this little project...
sounds like you will be wrapped up soon though.
Sounds like you are getting there. With cars like ours and the unavailability of some parts this is just part of the equation. You can always mess around with the old one too and see where its fitting where the new one wont.
My guess is that they didn't engineer new parts, but just made molds off good old parts. The molds degrade over time as sand sticks to the aluminum parts.
You also need to make sure your Top Dead Center Mark is correct and not off by 5°.
..,..and sorry I was such a dick. Some sellers get under my skin. It wasn't you.
and HA!... didn't take your comment as 'dickish' to me necessarily... I've followed too many helpful threads from you to think that ;-)
