Octane Booster on Track
With my GTS I played around with this by simply having my Launch X431 in my lap and watching the knock retard on a scrolling graph. If I quickly stabbed the throttle I could get a few degrees of knock retard on a couple cylinders. Once I added race gas concentrate I could no longer duplicate the knock retard. It would be better to do this on a dyno or with a closed course with a full loaded RPM sweep while watching many parameters, I was just trying to get a sense of if there was anything to this. With the latest gen of ECUs they are very dynamic and I did come to the conclusion that this helps.
BabyNSX (07-04-2024)
For what it's worth I'm going to switch from Boostane to mixing in some 260 GT 100 octane fuel. I found some local to me, I'll sleep better not using booster. Extra $34 per tank on track for piece of mind, is worth it.
Peter
It was the conversation between Jamie and Charles in the last whiskey Friday video, regarding tuning your car, that made me wamt to consider higher octane. I know the IAT's have to get pretty high on track with the air intakes pulling air off the front brakes and hot asphalt. Would just be cool to see if I could squeeze out a few more MPH on the straights, but I'm not about to spend $80 on 100 octane to mix in with my 92 to find out.
Well went to the track yesterday and couldn't get my datalog to work. Torque app doesn't log knock retard, so I attempted ignition timing, but the sampling rate is so slow unless you're watching the realtime data it wasn't worth it.
Anyways I did a long 23 minute session on 92 octane, then added the Royal Purple Max Boost along with 5 gallons of 92 that I brought with me. I didn't notice any butt dyno difference in the next 2 sessions, and while I did set a new best lap, I'll attribute that to better lines and later braking (still learning) and not any difference in power.
I compared speeds in the garmin videos before/after the octane boost and there wasn't any discernable difference in MPH.
I'll throw a few gallons of 100 octane in next time I'm at this track and do the same comparison, but I don't think it will change the outcome in my use case.
Yeah, Jamie and Charles got some visability into our engine's sensitivity to octane during the latest tuning efforts on my car. We found that sensitivity to be there when we worked on the Pro-tune last year. We managed to work around it and develop a very solid 91 octane map, but it was power limited, even if there were still significant gains over the stock maps. I'll be paying attention and logging things for a while with the new setup - which I'm absolutely loving!
Does the Pro Tune mean you tuned the car on a dyno?
Your looks amazing by the way…
@BabyNSX did you notice is big difference in power or efficiency or sound between the standard 91 octane COBB map and the Pro Tune?
GianniG60 (07-06-2024)
I went to Thunderhill this past weekend to run their 5-mile “Thunderschleife” configuration and ran my GT4 in 110F heat. Track surface was as high as 160F supposedly. My car saw 270F oil temps after a couple of laps (so 10 min in) and I would do a cool down lap. Nice to see temps drop somewhat quickly - probably 2-3min to get down to 250.
I mixed in 4 gallons of 100 octane with 91 to see if it would help oil temps or performance and I didn’t see any change at all. It got hotter so my car saw 280 and top speeds were identical so no performance gain that I can tell.
Unfortunately for my friend with a PDK GT4 his car saw 300+ oil temp and got warnings on his screen. He had to do frequent cool down laps.
We are looking to add RS underbody venting in hopes of getting better cooling. Btw my friend with a 991.2 GT3 never saw higher than 230F oil temps lol.
Are you referring to the cooling ducts that can be fitted under the car to help cool the axles/CV joints? or are there other cooling solutions for the RS that are not on the standard GT4?
