Akrapovic OAP
Are these still available anywhere for the 2023? I understand there are some fitment issues with the newer model years and can't seem to find them available anymore?
NS_MACAN_GTS (06-14-2024)
Thank you so much - just called them and was able to get a set! My dealer is asking for $1200 to install which seems kinda nuts!
gt4sf (06-15-2024)
It took my shop about 3 hours to install since they had to take the wheels off and it is a tight area. I imagine they are being safe and thinking 4 hours, which makes sense at $300/hr shop rate.
Go to a good independent shop.
gt4sf (06-15-2024)
I see you are in NJ. Me too. PM if you want help installing. I did this recently on mine and is not difficult. Only reason it takes 2 people is the cumbersome size of the exhaust when you remove. And be prepared to replace the bolts if the studs don’t come off. Should be an hour maybe 1.5 hours max to do if you include BSing around.
Steve
Steve
Basic Sponsor
lovetoturn (06-16-2024)
