Double up on PPF
For you guys that have had a GT4 RS for a while, where would you recommend doubling up the PPF? I'm sure behind the front and rear wheels ,but is there anywhere else that takes a beating?
I wouldn’t double up. Just go with the Xpel 10mil, or similar, on high impact areas.
NS4RS (06-08-2024)
Most definitely. Most of my miles are in the mountains, following other GT cars resulting in constant sand blasting.
I'm now a firm believer w/ 10 mil PPF full car and double up in high impact areas.
Annually, I try to revisit my PPF shop for any touch up/inspection....which makes easy work to peal up a double layer and apply new.
Mr. Adair (06-08-2024)
That’s low.😈
BlazinPond (06-09-2024)
I'm surprised they can peel a top layer of PPF off a base layer. I may look to do this as well in front of rear wheel wells.
