GT4RS - oil leak - oil sump gasket
jimjoe997 (03-17-2024)
RDCR (03-17-2024)
#34
Looks like using wrong motor oil...not the new GT stuff
#35
#36
A friends 992 GT3 with the same failed gasket. It is now a known defect in manufacturing. Cracked in the same place and in the same way.
jimjoe997 (04-02-2024)
#37
Same type issue in my ‘23’GT3. Hopefully my ‘24’ GT4RS doesn’t have this issue.
#38
My 4RS was OK at 1400 miles for the first oil change. It appears to be a manufacture's defect during assembly.
#39
From the picture of the damaged gaskets it looks like something that would show up relatively quick as the gasket probably was failing from day one.
Looks like much more of a manufacturing defect than an installation defect.
Once the pan is put on, there are no lateral stresses on the gasket that could tear it .
#40
I would call this a design defect, not a manufacturing defect.
4carl (04-03-2024)
#41
Friend just had this happen to his 992 3RS at 10k miles.
redpriest (05-08-2024)
#42
That's me! Yep, for my case they were able to do it without having to drop the engine. This leak didn't manifest until probably 20+ track days and 8000 miles or so. I've had the diffuser off many times and the engine bay was spotless.
Fortunately, I monitor my oil like a hawk, so I didn't lose that much. Just enough to make a mess and a tiny puddle on my garage floor.
#43
#45
Had the same issue on my ‘23’ 992.1 GT3T at about 1000 miles.
