GT4RS - oil leak - oil sump gasket
Just wanted to share a data point, not seen anyone mention this issue yet.
My GT4 RS with 3,800 miles started to leave oil stains on my garage floor. Off to the dealer it went and they determined that the "oil sump gasket" leaking.
Apparently quite an involved process to get to it, engine out job. Makes you miss the 911 layout, doesn't it!
Will see if the job card provides any more details when I get the car back.
what was your production date?
TripleL (04-03-2024)
One more data point... my 2023 GT4RS has a small oil leak. Engine has to come out to fix it. I will try to get pictures to post here.
This is what was causing the leak.
The following 3 users liked this post by jimjoe997:
Other pictures from the repair (for general interest)
Good time to call Jamie at Dundon. Perfect time to upgrade.
@planolemans
Yes, engine out was necessary. Initially I was hoping that they just had to tighten a bolt or the oil filter. Nope.
The car has about 4000 miles on it, with 6 HPDE track days at VIR.
The leak is really small, it would be easy to miss.
But looking at that green gasket, it seems like this repair is essential. And very essential to get it done under warranty because this would be enormously expensive otherwise.
Sigh. What this tells me is that the GT3 engine was force-wedged into the 718. Yes, it fits, after they moved the sump in the this gen of the engine. But it was not designed to fit the 718 -- at least not with proper design considerations given to service.
I know parts bin specials are a Porsche specialty. But when the bin part is the engine...
dnimi123 (03-10-2024)
I think this was just an unlucky and rare occurrence (hopefully).
