GT4RS Sounds / Noises - normal or not?
Ok so I am paranoid. I’ve had the GT4RS for about 500mi now. I’ve heard some noises I wonder if they are normal.
Normal? Not normal?
All the other interesting sounds etc all match the ‘18 GT3 I had.
- Around 0-3k rpm with 1/4 throttle I get a buzzy noise I think could be the intake assembly. Only with low rpm’s and bass tones does it happen
- I notice a clack (or click) sometimes when releasing the brakes. Comes from around the engine area.
Normal? Not normal?
Over the years. I’ve had five GT cars 996 gt3,996gt2 2-781 gt4s and my current 992gt3 .
They all make strange noises probably the worst was a 996 Gt3 idling it sounded like a can of nuts and bolts rattling.
When you turn tight the rear end would skip because of the locking differential.
Current Gt3 mainly interior noises.
I just picked up a 992 GTS That’s the first 992 out of three of them that hasn’t had a rattle ..
I guess three times is a charm
Is this the sound? Around11:15 into the video -
Listen at 4:45 this is one of the best examples I found, firstly you hear the intake noise then after that comes the buzzing noise etc. You can hear it in the background just ignore the person talking.
sunnyr (01-09-2024)
I am on my 2nd GT4RS.. first one was non Weissach.. and ONLY at low RPM 1600-1800 a high pitched rattling vibration sound.. I don’t recall noticing on prior car.. and am very accustomed to all the other garbling GT motor sounds.. this one is high pitched.. like the brittle carbon fiber air box is vibrating loudly.. if anyone has played pinball recently .. sounds similar but much more annoying like the playfield glass rattling from a cabinet shaker
