kline vs JCR
Nobody thinks their exhaust drones until they experience a bathroom emergency a long way from a rest stop. You will very quickly learn which rev range to avoid under those circumstances.
The following 3 users liked this post by Reedy:
I love my JCR race pipe and get complements about it all the time. I haven't heard a Kline one in person yet but from the videos they sound very good too. Only a few of the aftermarket options get the right flat 6 wail that the car should have come with from the factory.
I only wanted to replace the muffler and from what I can gather Kline only does the whole system, I didnt think it would replace the muffler only.
However, I do highly recommend the whole system as the headers really make it.
sound-wise JCR seems more high pitched but it seems like consensus on Kline is that it is drone-free
for new the JCR rear section costs even more than the Kline stainless setup. certainly makes Kline seem like the more economical option. however you get titanium with JCR. quite a bit more $ if going for Kline inconel
Much less drone than stock, IMO and none of that stock "boomyness"....
It is also definitely high pitched, but might not be quite as high pitched as the JCR, but it sounds very good.
I'm running a CGTS, with the catted, silenced race pipe, with Manifolds. It can get buzzy and some drone in the 2-2400 rpm range. Most of the roads around me are 60+, and we're doing 65, which is 2800 rpm. So windows up it's no problem, in the 55 mph range it can be uncomfortable if you're stuck troddling along with the windows up. I find cracking the windows can be an improvement. It's still a HUGE improvement over the valved Fabspeed I was running, so don't even try to compare it to that. Also, if you're getting the non silenced JCR Race system (which it sounds like you are), you can always sell the non silenced section and buy the silencers from Jonny, and integrate those into your system. The sound above 5k is amazing, and the GTS does have some added insulation compared to the GT4 that Joe above has. There is a small amount of drone, if you go looking for it, but it's very managable and easy to minimize with windows down. Like RP2000R said above, you won't be lugging it around in this range. I love the tone of the JCR and it's well worth it....but obviously roads around you are going to dictate that.
I started with the manifolds, and even with the factory oap and rear box, there was some boominess in the system. While I know others discuss that the KLINE has no drone, I feel like you're sacrificing something to get the no drone. My other piece of logic is that moving most of the silencers/cats to the way back of the car, it's much improved over some other systems, like the Fabspeed, where you have the resonators moved forward. Just my random thoughts, and I'm sure others will state that it doesn't matter the location, but it does come down to frequencies and where those frequencies occur in the rev range, as well as where they hit inside the cabin.
I have KLINE exhaust and OAP + CARGRAPHIC sport cats
Love it!!!!!
No drone, perfect!!!!
https://youtube.com/shorts/aX90kkZLVnw
Love it!!!!!
UncleDude (05-03-2023)
I would say not much more volume since the stock box valves open dumps the gas right out of that short stem. Valves closed I would say the aftermarket ones would be louder (this has been my experience).
brandobot (05-03-2023)
Agree! Adding JCR back box to the Flat6 OAP didn’t appear to add additional volume - at least to my ears. The JCR just changed the exhaust tone.
I think that's the one thing some people don't realize when they start with the OAPs, or other items. It isn't always about the louder exhaust, it's about the tone, which the factory does a poor job of when you start leaving the valves open full time, or overriding the factory PSE. Both systems are great at this, each of them goes about a bit differently (Kline back box with special OAPS), or being able to configure your system to your desires/wallets. That last one is probably the most important!
SupremePower (05-04-2023)
