GT4 Wing height
GT4 Wing height
Anyone with a standard GT 4 wing able to tell me the measured height from the top of the wing blade to the roofline ? ie how far below the roofline is the rear wing blade top ? THANKS !!
I can take a look. Wing is currently at max angle of attack using the stock bolt so the measurement will be a touch shorter than it could be.
Trailing edge Rear wing to roofline height
Leading edge Rear wing to roofline distance
Pretty rough measurement. Not level floor, not long enough straight edge, cold and I broke my bubble level.
I held a straight board over the roofline, extended it back with some trickery and measured from the black line on the white board pictured. At no point did the white board move location so... should be within an eighth or two my guess.
Don't get protested on my account 😬
rubber_ducky (02-14-2023)
