Metal "Clunk" noise when releasing brake from stationary position
Hi,
As the title suggests, I'm experiencing a metal "clunk" noise after I release the brake to pull away form a stationary stop. Is this normal for a PDK GT4? My manual car certainly didn't do it.
Car is literally brand new with 25 miles on it. First time driving it today.
Thanks,
Nick
Thanks,
Nick
That sound will not be coming from the PDK, it is operates more similar to a manual clutch engaging. If it is, that would be a problem. My guess is it is coming from your brakes. Either a loose caliper (unlikely), or a stuck pad, or most likely, the ebrake grabbing and needing adjustment.
At 25 miles, everything is just bedding in. Drive it with some intent, and get the brakes up to temp - would not be surpised if the sound goes away.
Larry Cable (12-21-2022)
Thanks, I should’ve said - it’s coming from the rear of the car. So highly doubt it’s anything to do with PDK. Almost certainly the brakes, initially thought it was the auto hold releasing. But it’s not showing on the tac
nixsky (12-21-2022)
Hi,
Thanks,
Nick
Thanks,
Nick
The following 2 users liked this post by UncleDude:
Chrismalberts (12-22-2022),
rp2000r (12-21-2022)
The car was valeted just before I picked it up (after PPF was laid). I'll let it dry out and give it a test drive!
Thanks for the suggestions! Sorry if I'm being precious ha
