Engine misfire / oiled air flow sensor
I recently cleaned my BMC air filters and believe I may have over oiled because I am getting misfire codes now. It sounds like a common problem is with an oily MAF or MAP sensor which can be easily cleaned, but I can't find any information on its location on the 718 GT4.
Can anyone point me at where to look?
Thanks!
Thanks!
Thanks!
Thanks!
Alan C. (11-01-2022)
Does it miss fire when the engine is at operating temperature or just until it gets warmed up?
I figured out the part I am showing above is the MAP, so I cleaned it and reinstalled. It sounds like our cars only have MAP now so I think I am good. I also noticed it was quite oily, so I am pretty sure this is the problem.
Ahhh, ok, different than mine which exhibits a stumble under load as it is coming up to operating temperature, once it is fully warmed up the engine run smoothly.
