Just installed.
Only thing I had to add was 7 washers on each side because the screw was getting too long for my wrench.
Other than that just plug and play. I think they look awesome. The satin finish is nice.
Are they as perfect as the OEM WP tips...of course not. But for $2400ish less...no-brainer.
Don't forget to clean with alcohol and prime with WD40 or similar after installation.
looks great! Could you share what diameter washer was needed?
Not sure if they are all made exactly the same but the bolt mine came with was 17mm. The washers I used were 10mm inside diameter. As suggested I reused the OE tips inside spacer rings.
knock off weissach RS tips black powder coated titanium... impressed with the quality. and price, under $340 shipped. thanks 'BoxKing' for steering towards these
To those buying off Ali… I used the Retailmenot App to find a coupon. Right now there is a $40 off code for Ali “USAFF40”, which makes the purchase that much easier on the already light entry cost in comparison to similar options.
Thanks for those that found this. Going to order today but can't get any of the coupon codes to work right now. Will give it a shot later but these look great for the price.
@Spyder 718 Can you elaborate on the WD40 thing? Is that so it will not have any fingerprints or does this help the tips burnish and gain color?
I was curious about this approach as well. I assume it was for cleaning purpose only. I didn’t go the pre installation cleaning approach, wasn’t even on my mind bc mine are black, though it might be a good idea for the other color variants. My tips changed color(s), I didn’t expect this, but it was a welcome change.
I’d like to know the P/N for the inner exhaust tip ring as well, bc Im planning on selling my OEM exhaust system OAP/Rear w/tips, and it would be nice to have them attached for the next owner. For those who dont want to remove them from the OEM tips, just do it, only takes a couple minutes, and it’s easily reversible.
I can't imagine the inner ring having a separate part number. The oem tips are one unit made by a OEM supplier.
Either P/N 982251188A made by Sebring or P/N 982251188C made by Remus.
I think Sebring is part of Remus so basically it's the same company. Best bet to find these inner rings would be to reach out to them I'd think.
The inner sleeve/spacer is not a separate part, but included with each tip. Both the standard made by Remus and Weissach Package made by Akrapovic
have them included... Also note that the clamps between the two are identical from Porsche with a 997 part number. WP is removable, but the standard, Remus ones are spot welded on.
