FitcamX Install
lowbee (02-03-2024)
#32
Unfortunately, I do not have a video with the filter in place.....and the Spyder is up on the lift for the winter. Might be too late, but I can get a video in a few weeks once the weather starts being more condusive to Spyder drives.... I will say though that the filter does make a substantial difference, but it does not eliminate the glare completely.
#33
#34
Does anyone know if speccing the preparation for dash cam on the SRS make it easier to install a 3rd party dash cam such as the FitcamX? Heard enough bad things about the OEM Porsche one to look at other options. Also, wondering if installing a windschott allows for a rear camera to be installed on it, too.
#35
To your second question, I'm not sure. I have the rear camera and the Winshott but I have not installed the rear but did think about installing it on it.
hk43 (02-05-2024)
#36
TubaFreak (02-05-2024)
#37
I have been back and forth with FitcamX tech support for the last few days to see if they can supply a short adaptor loom from the camera to the Porsche dashcam preparation wiring plug. They don’t have the correct connector as of now, but I sent them a link for purchasing the plugs and they’re looking into it. I’ll try to update on here when I get a final response either way. Whilst the loom that taps into the light circuit seems to work fine it seems to me it would be better to use the dashcam prep supply for those cars that have it.
#38
I don't get this. It does connect to the OEM "pre-wire" as it plugs into the OEM harness. What do you hope to gain from wiring it into the Porsche dashcam pre-wire? It is literally plug and play as it is.
mc3456 (02-27-2024)
#39
Fair. I guess similar to what Robmac123 said above, I just like the idea of not drawing too much off one wire, especially one that wasn't designed for it, even if the added draw is still within spec. For those that got the extra pre-wire, having the added option of connecting directly to it is a good thing, in my opinion of course.
MaddMike (02-05-2024)
#40
#41
Also, if connected to just the light manifold you don't have the ability for it to wake on impact when parked AFAIK. It needs to be hooked up to the fuse for this useful feature to be possible, which is a valid reason to wonder if the FitcamX can take advantage of the OEM pre-wiring I think..
#42
#43
If I order the Porsche dashcam prep, does anyone know:
1. Does the factory energize fuse locations in the driver-side fusebox, or the passenger-side fusebox, or both?
2. Am I able to instruct the factory to energize this fusebox or the other fusebox?
3. Which fuse locations are energized in which fusebox?
4. Capable of providing how much power -- amps -- and what size fuses?
5. Switched power -- turn off the car and the power to the fuse turns off? Or constant power -- the engine is off but there is enough "trickle" power to keep a dashcam working in parking mode if the car is hit or bumped?
6. Who might have a diagram or map or link to a manual that identifies fuse locations and fuse sizes for x or y systems in the car?
In advance, much and many thanks.
#44
So I ordered the Garmin Polarized lens cover (010-12530-18), test fitted it and don't like how it fits over the FitcamX so I returned it. It is a little bigger than the camera lens and the top of the polarized filter is touch the inside of the windshield. I will ask FitcamX what will fit best then report back.
#45
