Sport Cup 2 - Michelin's Advice on Pressures and Temperatures
#31
This is old info from the original Pilot Sport Cup tires (circa 2009). This document is still available on Tire Rack's website here, but I wish they'd remove it as it contains out-of-date info.
Attached (below) is the newer data for the Cup 2 tires...in summary, they want to see slightly higher pressures. These are my notes, created (mostly) from that doc so that I have everything I need in one place.
Michelin Pilot Sport Cup 2 Tire Pressure:
- Cold tires: Inflate with a pressure between 29 psi and 35 psi front & rear; never allow the pressure to be below 28 psi cold
- Hot tires: The optimal operating pressure must be between 33 psi and 39 psi front & rear; some vehicle models will need a higher inflating pressure than 39 psi hot
- Autocross: Though autocross hot target pressures are the same as those for road racing, you may need to start at a higher cold inflation pressure to compensate for the lower pressure gains in autocross racing.
- Rain: For both autocross and road racing, you may need to increase tire pressure 4 – 6 psi over cold, dry pressures.
#32
FYI Manthey Racing run their "Porsche Experience" cars at the mfg recommended values...
#33
Where is that extract from? Is it N1 specific or is that a generic Cup 2 recommendation? I found with non OE stamped tyres that about 32-34 was a sweet spot but the N1's on a GT4 are a bit different to the generic ones.
For what it's worth, Manthey Racing recommend 1.9bar front and 2.0 rear, HOT. That's 27.5/29psi. That's even lower than I have been advocating but far as I'm concerned that's damn near the end of this argument for people doing track days.
Now I know this thread is about what Michelin recommend but there's what Michelin recommend based off their design parameters, and then there's what's fastest in the real world. My own experience is anything higher than 29/33psi produces much, much slower lap times.
(skip to 6:50 mark)
https://youtu.be/g3nRNynNsXQ?t=410
(skip to 6:50 mark)
The stiffer sidewall tires (SC3, SC3 R's, AD09's, etc. ) suit the GT4 platform very well.
#34
(skip to 6:50 mark)
(skip to 6:50 mark)
I agree with @Reedy - arguments, "end of"! - MR have forgotten more about track setup than all of RL combined knowledge thereof (IMO)
#35
