12V Outlet
Well I used to use it for the battery maintainer but it seems to have stopped working and it won't work as a power source either , irrespective if the ignition is on or off .
The center console outlet works well for charging and as power source...
Try a different plug? Maybe it's not the socket.
Believe it is a separate fuse.
I blew the footwell fuse on my 987.2 using the tire pump. Learned later that the tire pump was supposed to be used on the console socket which had a larger, separate fuse.
