Mirror Tilt in reverse
I used my laptop and PIWIS 3 is the dealer software. It is possible to code this by the dealer but will they actually do it for you. A lot of features are already in your car, you just need to find the right settings to enable them. For example, Windows rollup or down with the Keyfob, Turn signal set to 5 blinks etc... Talk to rnlst_log if you need PIWIS 3. He provides excellent support
perhaps we should start a "sticky" thread containing such features and their PIWIS coding/settings?
Some features are in the same modules. Some others are not. For example, 992 has a lot more setting for mirror tilt. The hardest is to find the right setting in German. Google translate is my new BFF
Another important note is that there is a global setting for your car and also for each of your keyfob 1 and 2. I just coded all of them. It took me a while to figure it out until rnlst_log pointed that out. If you have the Carlink adapter, unplug it during coding, it will interfere with the PIWIS and give you a black screen on your LCD display
Does this apply to GTS as well that you don't have this feature unless you get the memory seats
Hi there. Can you let me know which lines you coded within the modules? I couldn’t find them earlier in PIWIS
Finally coded the Mirror Tillt in Reverse with my LWBS. I could not have done this without @rnlst_log . I kept bugging him day and night lol. I always thought that this feature was built in the memory seat or windows switch module. @rnlst_log convinced me not to buy the module and looked for the coding values. I used PIWIS 3 he supplied to code this feature. The settings are in two modules Kombinstrument and Tuer Vorne. I have the folding mirrors with no memory seat buttons. Next will be to find the Tilt angle setting if there is one. Thank you @rnlst_log you're the coding guru.
My passenger side mirror tilt down when in reverse but I never like this feature and I was able to disable it on my other cars. I have memory seat and I went through the PCM setting options but didn't see a way to disable it. All I was able to do is manually hit the driver side mirror button to stop it from tilting down each time. Anyone found where is the setting to disable it ?
Cheers.
lowbee (06-29-2022)
lowbee (06-29-2022)
Thanks guys, found it. Appreciate the help
