Rattle/knocking noise top center dash (Spyder)
Anyone experience a knocking or lower pitch rattle noise coming from the center back of the dash (close to windshield)? Seems to be coming from behind where the clock is (maybe below speaker grill). Happens at any speed and even small bumps at low speed. I’ve tried pushing on the panels to isolate but it seems to be something underneath the dash. Driving me crazy. Anyone experience this or know how to get a peak inside this dash area?
you can pull the sport chrono panel off the dash fairly easy. there are walk-throughs if you google it (look for how to change the colored face and one will show you how to take it out).
Warranty claims for dash noises usually involve fixing the problem and creating 3 new annoying noises. Dashes are rarely designed to take apart and put back together to the same tightness they were before it was disassembled. I would most likely not want someone ripping my entire dash apart trying to find a random noise.
Litt (10-26-2021)
How many miles on it? How long has it been happening?
I have sold cars before for a squeak/rattle so I feel your pain. If you cannot figure it out on your own take it to the dealer since you have nothing to lose. But before you do spend some time online to see if any 718s have a simliiar problem since the dashes are about the same.
Litt (10-26-2021)
5k miles, started about 4k miles. I may just have to take it in....its loud and annoying enough that the car has lost some of its appeal to me while its there. I did some searching online but could do some more. Hard to believe I might be the only one hearing this.
I have a rattle in my Cayman GTS 4.0. It's not loud enough to hear with the window down. Only with the windows up. I hear it mostly at speeds under 40 mph. Initially, I thought the key/fob was jiggling in the ignition or that the lever on the left vent was loose. That's the area I hear it. I might take it in later in the month.
I'm babying my engine (still under 1000 miles). So, no revving above 4000. When I'm going over 40mph, I hear the rattle less, and that's not because high revs drown it out (because of babying). It seems like higher speeds quiet the rattle, but I might be projecting.
Has anyone figured out what's causing this noise? I'm having the same rattling noise that @Blainerunner described, I sounds like it's coming from under the dash/ steering column trim area.
after having studied the problem well, I ended up finding that it comes from the cup holder integrated into the dashboard. the parts vibrate with each other.
I integrated foam inside and since then no more noise.
The following 2 users liked this post by hugo993:
RAGT4P (04-07-2023),
santiago660 (04-07-2023)
