New Video! AP Racing by Essex Brakes vs. Stock Porsche GT4 Brakes
#31
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20160422_172339_5dc1505839f4bce6356d7e882badbff0fc89cca6.jpg)
#32
Seems like it's the same caliper, maybe slightly different hardware/brackets?
Would you offer an upgrade kit?
I'm asking because I have a 718 GT4 incoming early next year and then hopefully getting delivery on GT4 RS in the summer.
#33
Basic Sponsor
What's different between the 718 GT4 kit vs the 992 GT3 kit?
- For example, if you own an 991 GT3 and want to go to a 992 GT3, you would need new front disc assemblies and brake lines. The entire rear kit from the 991 GT3 would bolt right up to the 992 GT3.
- If you owned a 718 GT4 brake kit and wanted to move it to a 992 GT3, you would need new front and rear disc assemblies and brake lines. The Caymans use a 5 bolt mounting pattern, whereas the GT3 variants use center lock.
- We don't yet have data on the GT4 RS, but our expectation is that it will be a simple swap with a few new parts, just as it is with any of these other variants.
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
![](https://rennlist.com/forums/signaturepics/sigpic110137_8.gif)
Jeff Ritter
704-824-6030
#34
#35
@electron mike Yeah, but when you get the RS, I'll have everything envy!
I consider these my fancy pants PCCB budget. I have to say that after just a few bedding and shakedown street miles, I think they're incredible, and that's saying something as the OEM iron brakes are IMO very good, and considering many of the claimed benefits of these involve track related consumables cost and heat tolerance. I'll have more to say after I get some more miles on them, but I suspect my observations will just mirror the usual positive reviews. They aren't for the foo foo starbucks polisher crowd tho... they make some racecar noises which I love, but will drive some ppl's OCD nuts. Like a big brake pad clack clack when I go from forward to reverse and vice versa.
WRT the wing, I don't think @DesignsbyJacob gets enough love. It's all function over form, yet the wing looks awesome IRL... tho among my friends, its aesthetics are quite polarizing. Lots of detail on the risers that doesn't show up in pics, and I really dig the proportions, especially when viewed from the front 3/4. I'll try out the splitter and some slightly aggressive AOA prob mid Feb.
I gotta put in the headers + OAP next. I have a feeling you have me beat in the exhaust regard; I may be taking a step back / get kicked out of my track after running that setup for a bit.
#37
Interesting the pads clack when switching from F to R. My M3 did that with pagid yellows as they were a bit of a loose fit. The Ferodo DS3.11 that I used didn't do it. Which pads are you using?
Agree on the DBJ wing, if I don't land an RS I might have to get the bigger wing just to have a nice picnic table out back for lunch at the track.
#38
Currently running DS2500. Rears currently have no tensioning springs (Covid supply chain issues), but fronts do, and the F to R clacks are most noticeable from the front. Now that I think about it, both the OEM and the DS2500s I have in my M have what I think is a milder version of the clack. I think the Radi-Cal calipers are designed this way; the pads have noticeable margin to move, prob on the order of one mm, both radially and tangentially. I believe this is to let the pad backings expand without binding when hot. The fronts have Essex supplied springs which press the pads toward the axle (and quash rattle when hitting bumps), but not a set of springs which press them forward or back tangentially. Either way, I'm fine with the clack, but it'll prob be offputting for the polisher types.
I gotta stop at a coffee shop during a cruise sometime soon so I can have coffee on the wing.
#39
The 981 and 718 GT4 use different discs vs. the 991 and 992 GT3, but we will offer upgrade kits to swap among any of these cars.
Hi Jeff...thanks for the info on the 992. As you know the 992 GT3 (with Iron brakes) uses the 408 mm disc with CL, same for the GT4RS.
Will your kit bring down the rotor size so we can use 19" wheels or will it fit at 19" without a change in rotor size??
Almost sure any info you have for the front of the 992 GT4 brakes will translate to the GT4RS.
#40
#41
Probably so wonder how The AP brake kit gets down in rotor size when using their 992 GT3 kit......this is looking like an option for me before ordering new Forgelines for the 4RS.
#42
Basic Sponsor
Below is a pic of a black 992 GT3 OEM caliper...note the larger boss hanging down from the caliper on the right side of the picture, below the bolt head. Those bosses push the caliper further outboard to accommodate a larger disc when it is mounted.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1333/992_gt3_fitting_30__4b86cb73aa3688ca7aeb1e05899547cafc600753.jpg)
Below is a shot of a red OEM caliper from a 991 GT3 with iron 380mm discs, which is the same caliper as the 981/718 GT4. Note that there aren't any bosses hanging down, which means the caliper doesn't sit as far from the wheel hub when bolted down.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1333/dsc_0021_d7922bc9d21440b8ef39c4e160d1c5d460395e09.jpg)
Below are some pics that show the difference in caliper height between the AP Radi-CAL and the 991/981/718 GT3/GT4 front caliper. The height difference is even greater with the 992 GT3 front calipers, because of the taller boss as described above.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1333/dsc_0006_930aa98fe18c62a21708e500ede750416502e882.jpg)
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1333/dsc_0015_58475c4a483714da31f84a5a7495018f2932cd5b.jpg)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1333/dsc_0013_2795c1b94a2a4ffca46bd682d789c8d5212beb85.jpg)
In summary, our AP Radi-CAL setup is more compact by a considerable margin, while still providing ample thermal mass to get the job done. Our system offers superior wheel fitment and will offer more space when trying to fit smaller, lightweight wheels.
jwr9152 (01-19-2022)
#43
Basic Sponsor
Bumping this tech video walk-through of our product vs. stock for those who missed it previously. Thanks for your continued support gents!
