Brake air duct fell off
I tore one off of my GT3 following an "agricultural" line at the 'Ring - replacement was no big deal...
Don't forget to order the support (bracket), and bolts.
if you happen to have an IR temp sensor you can always compare ducted. vs non rotor temps if you are concerned!
you will be fine - just make sure that you are diligent in your cool down lap ... one day of tracking w/o brake ducting will not kill your pads or rotors...
Larry, did the measurements yesterday. Out of two sessions the non cooled brake rotor was between 10-15F hotter than the other side. Like 175F vs 190F. So pretty significant! Haven’t felt any loss in braking performance though.
