Help Please! Need TPMS help
I'm adding a set of FF11s w/PS4S N0s for wet and daily driving use but I'm really stuck finding the correct TPMS monitors. Here is what has happened:
TIA,
P.
- Sent TPMS Direct my VIN and they specc'd a 433 MHZ Huf intellisens PN 9A790727502. I placed the order May 19th and still no sign of them. I called the seller and all I got was "call USPS".
- Called a local dealer and was quoted $249 each for all the bits. When asked, I was told the sensors are in fact 433 MHZ. When I google the PN they provided (PAB907275), my research states that they are 315 MHZ. DOH!
TIA,
P.
TIA,
P.
TIA,
P.
Exact sensors that are on my winter wheels
HUF Sensor : RDE047V21
HUF Valve kit: RDV021 (43mm)
https://www.tpmsbargains.com/PORSCHE...PMS-s/1732.htm
OE sensor is RDE047 as stated above. You can also use Huf programmable sensors for that application hence the price difference of these listings. Same manufacturer, Same process to relearn.
