‘21 GT4 - OPF / GPF Delete, which product to choose?
#32
But to answer your question, there’s no reason not to...
A gutted GPF is not a “resonator”, so unsure where’d you get that idea. I imagine they flow horrible as the exhaust hits a flat plate and fights two exit paths.
What are you trying to fix with your car and this mod? It will increase volume.
#33
This. Really not my cup of tea at all and I’d avoid a car that’s had it done.
#34
To TXshaggy: Cargraphic is a good german company that is often refered in this forum. They sell a product that mimic the oem oap at big$ and without heatshiels ( separate option $ ). They promote this design saying their product match the sound specific vehicle brand. Fot them this "resonator" is a plus.
#35
#36
Those Cargraphic OPF deletes with the cannisters still on them are puzzling to me. What is going on in there exactly? Anyone have these and have a photo of what's inside? They call it a 'mixing chamber' but unsure what it's mixing.
Interesting they are also citing power gains when I've read testing elsewhere claiming power gains are negligible / borderline unreadable (of which I still find hard to believe given there was a giant blockage in there prior, you'd think freeing it would afford you something).
#37
theEnd (04-02-2021)
#40
Looking for any recommendations on which GPF delete to use w/stock mufflers for a new ‘21 GT4. Just looking to remove the restriction and enhance sound a bit, I’m not looking to go crazy modding.
fabspeed, soul, akra, others? Any pros and cons vs all of these?
any vendors there with a good shop in Houston Tx area that can put a deal + install together?
thanks
thanks
If your familiar with the 991.1 PSE on their normally asperated (NA) engines, this mod to the GT4/Spyder is good, but its not 991.1 PSE, NA good.
All in all I'm happy I made the investment. As @dnimi123 mentioned, call Eric at Supreme if you want the Akrapovic.
#41
If you want OAP's you best get them ordered soon. EPA's coming down hard on the aftermarket companies and to top it off, supply chain and raw materials issues/shortages are happening and will eventually hit these manufactures. It's a double whammy of sorts. The C6 & C7 Corvette guys have been feeling this EPA pinch for a couple years now...
phefner (04-02-2021)
#43
With that being said, I guess technically many things could be described as a resonator.
Great bit of marketing though; empty GPF = Resonated Exhaust.
No need to convince me though...I’m good with the Soul solution
#44
around 0:54
#45
Received 3,447 Likes
Still waiting to hear back from Soul as to when their over-the-axle OPF delete pipes will be available - maybe someone else will have better luck trying to find out.
