Porsche 718 GT4 BBi Autosport Roll Bar Suspension & Akrapovic Exhaust Install
Basic Sponsor
Attachment 1335528
Porsche 718 GT4 BBi Autosport Roll Bar Safety Package & Akrapovic Exhaust System Installation
Featured Install ➡️ We recently installed our BBi Autosport StreetCup Harness Bar, BBi Suspension Package, and Akrapovic Exhaust in this new 718 Porsche GT4! All BBi Autosport 996/997/991/981/718 StreetCup Bars in stock and available worldwide through our growing dealer network. New dealers & wholesale inquiries welcomed. Please email sales@bbiautosport.com for more information!
Upgrades
Constructed out of lightweight high-grade titanium, these systems are very well engineered and deliver power gains of +6.4 hp at 3,000 rpm and a torque increase of +11.6 ft-lbs at 2,900 rpm recorded on the Akrapovič dyno.
Akrapovic Exhaust System Installed
To tighten up the handling, we upgraded the suspension with our BBi Autosport Spring Kit, Rear Toe, and Adjustable Sway Bar End Links.
Corner Balance & Alignment
BBi Roll Bar Safety Package Installed
Finished Project
BBi Autosport 718 / 981 GT4 StreetCup Harness Bar
Attachment 1340538
Key Features
Attachment 1340539
Attachment 1340540
Attachment 1340541
BBi Sub Belt Bracket
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
When equipped with optional Sport Bucket seats, this bracket is required to install 6-point race harnesses. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
Product Link ➡️https://www.bbiautosport.com/product...b-belt-bracket
BBi Harness Install Kit
BBi Harness Install Kit included extended bolts to properly accommodate both the OEM seat belts and racing harnesses at the factory mounting locations on the 991 GT3 / 981 GT4 Sport Bucket Seats . This kit features metal sleeves fitted around the bolts so that the belt brackets can pivot freely on the bolt. Sold as a kit per seat.
Product Link ➡️https://www.bbiautosport.com/product...at-991-981-gt3
- Jerry@BBiAutosport.com
Upgrades
- BBi StreetCup Roll Bar
- BBi Sub-Belt Bracket
- BBi Harness Mount Kit
- Schroth Racing Harness
- Akrapovic Exhaust System
- BBi Adjustable Sway Bar End Links
- BBi Rear Toe
- BBi Spring Kit
Finished Project
Attachment 1340538
Key Features
- Chrome moly steel tubing utilized for excellent strength to weight ratio
- Modular construction to allow access to engine for servicing without removing entire roll bar
- Shoulder harness mounting crossbar positioned at appropriate height as per Schroth's instructions
- TIG welded and utilizes "X" braces on rear section for superior strength and rigidity
- Mounts to frame structure and rear strut tower to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock or any aftermarket seats on the market
- Minimal effect on seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even curve
- Finished in satin black powder coat. Other colors available
- Bolt-in installation requires no drilling and minimal carpet trimming
Attachment 1340539
Attachment 1340540
Attachment 1340541
Features
- Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
- Precision CNC laser cut and bent from one piece high carbon steel for superior strength
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- Attaches to seat assembly using factory mounting points with all hardware included
- Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
- Made in the USA
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Just saw this post as I'm talking to a local shop to have it installed. In the features, it says "Minimal effect on seat travel to accommodate taller drivers." What does this really mean? I've had shops say that there is no loss of leg room. My seat is all the way back and all the way down (LWB).
Thanks,
matt
Thanks,
matt
Basic Sponsor
Yes, we use Swift Springs and we can share more details if you give us a call at 714 843 0200 or email sales@bbiautosport.com
Thanks,
matt
Thanks,
matt
Unfortunately the Akrapovic over axle pipes are no longer available.
The horizontal bar behind the seat impedes the seat travel so you will lose about 2 inches or so.
Basic Sponsor
https://rennlist.com/forums/gt4/9267...l#post13179089
Just wanted to give an update.
I did have the BBi bar and anti-submarine bars installed after testing it out in another car. The great news for tall folks like me is that with the fixed carbon buckets, you can move the seat all the way back and down with no loss. BBi, I appreciate your honesty and conservative estimate about travel loss but it appears to be a non-issue. Huge relief and very happy with the bar.
Thanks!
Thanks!
Basic Sponsor
Thanks!
Thanks!
