Cleaning and maintaining the convertible top
I guess this is something you Cayman folks don't need to think about but curious to know what you folks with the Boxster, BGTS 4.0 and Spyders are using to keep your tops free of lint, dust, and dirt especially when you go to fold the top down. This is our first convertible and I know I might get some flack for asking this but considering that my Spyder won't be a DD, it will be doing minimal driving through out the year so it will be spending some time in the garage collecting dust (unfortunately.) Since the compartment that the convertible top folds into (at least in the Spyder) is a felt lined space of sorts, are you using anything to "clean" off the top of lint, dust and dirt before you fold it down?
I saw some lint brushes at Costco this weekend and thought this might be something worth using. Anybody use lint brushes or do you have something else you recommend? Maybe some sort of horse hair brush?
skeeter714 (12-21-2020)
1) when parking the car in the garage, *always* put the top up, and use a car cover (keeps the fabric from creasing and getting dirty) ... also since the Spyders rear window is plastic keeps it in shape
2) use the Porsche cabriolet top protector:
3) *NEVER* *EVER* scrub or brush the material, you will only cause the fabric to pill
4) you can use a lint *roller* or a vacuum cleaner to lift dust or larger dry particle - again though do not "scrub" if using a vacuum cleaner head...
5) if you have to wash the top (to remove bird poop etc) never scrub the top, use a low pressure stream of water to dissolve/remove the contaminant
6) never scrub the rear window, always use water/cleaner to remove any surface dirt, avoid any contact with the surface to avoid scratching it ...
hope this helps...
The following 6 users liked this post by Larry Cable:
gr8ful4flat6 (06-22-2022),
halfmonkey (12-21-2020),
Magnetic K (09-11-2021),
StilettoPat (06-24-2021),
wizee (01-08-2021),
and 1 others liked this post.
Page 71 of the 718 owner's manual covers the basics of caring for the convertible top. It says:
- Brush off dust from the convertible top in the direction of the fabric lines using a soft brush
- Only if there is heavy dirt, moisten the convertible top with lukewarm water and a washing shampoo and a convertible top cleaner and rub gently using a sponge or soft cloth
- Rinse the washing shampoo and convertible top cleaner thoroughly off with clean water. Porsche recommends products from Porsche Tequipment.
- Treat the convertible top cover with a convertible top care product after washing at least once a year. Do not allow the care product to come into contact with paint or glass. If contact with paint occurs, remove the product immediately.
The following 3 users liked this post by Cirrusly:
The following 5 users liked this post by Merlotsj:
dashanin (04-25-2022),
Mikey K (01-09-2021),
Rupert16 (06-23-2022)
well in my experience with my '15 GTS Cabriolet I would suggest the following:
2) use the Porsche cabriolet top protector: https://www.amazon.com/Porsche-Cabri.../dp/B008VY1IWQ
hope this helps...
hope this helps...
RaggTop is the most popular convertible top cleaner / protectant. I've used both on a number of convertibles. Here's the kit on Amazon. From what I've read on other forums this is the same protectant that's private labeled by many of the car companies, and I believe one of them is Porsche. I'll buy a can of the Porsche protectant and compare them and report back. RaggTop recommends soft scrubbing with a horsehair brush (included in the kit) with the cleaner if necessary to remove any stubborn stains. If you keep to top protected with the protectant during normal washes you simply rinse it off. You do not use your normal car soap or wash it the way that you do the rest of the car. Watch this YouTube Autogeek video featuring the founder of Raggtop who explains how to properly clean and protect your convertible top.
I use 303 Convertible Top Cleaner and Fabric Guard on my 2005 Boxster S about once per year to keep the top looking sharp, I probably will only use it on the Spyder every two years. I do NOT wash the top during regular car washes. My Boxster S is my daily driver, and stays outside of my garage. I will use a horse hair brush on occasion in the spring to remove pollen, I generally treat in the fall in California, and I drive top down unless it is raining pretty much. I talked to Moe at Glistening Perfection about the Spyder top when I talked to him about the work he is doing (full PPF and Ceramic] and he also recommended the 303 products.
Thad_Hawaii (01-01-2024)
Thanks a bunch for this information.
Again, we've never owned a convertible so don't have any experience of how to properly maintain the top. For one, didn't know to NOT wash the top like the rest of the car. Good thing I asked. Looks like I'll need to do more research as I thought this would be a simple answer but seems there's more to maintaining the fabric top even when garaged.
So you literally don’t wash the top but once a yearish? Assuming you spray it off with water during car washes???
Already have the Raggtop products on order. I do recommend they update their 1990s quality product advertisement video though. Felt like I needed to watch an episode of Saved by the Bell afterwards.
SicEmBears (10-11-2022)
Glad you asked also. I washed the top like the rest of the car day one and was so proud of my freshly cleaned car. Little did I know.
For me, with the car always in the garage and rarely up when I'm driving if the sun is out, I'd say on average that I put the protectant on once a year or so like the manual recommends.
Basically yes. If whatever it is doesn't come off with just rinsing (which it almost always done if you have it protected properly), as the Porsche manual and the RaggTop instructions say, you can use a sponge or really soft brush to wash it gently. The Porsche manual specifically says "shampoo and cleaner" and the RaggTop cleaner of course just says use the cleaner. I RARELY have to do anything except rinse mine off, but I do keep them treated well. Bottom line if water isn't beading up on them like it it does on a waxed car it's time to clean it and treat it.
It's protected from the factory --- will bead like crazy.
I don't think you really need to worry about lint honestly. That's only an issue if you use a heavily linting towel to wipe it down.
1) Use Raggtop as needed to clean and maintain beading, this should be needed more than 1x or 2x a year.
2) Don't use harsh soaps otherwise on the softtop during your regular washes.
3) Use a waffle weave or other microfiber towel to gently wipe down or pat dry the softop after washes.
