PDKS GT4 VS GTS what’s really different?
#31
I have a PDK 981 Cayman S. Even in Sport Plus, the PDK "manual mode" is not completely under control of the driver. Depending on how you go to throttle, it will kickdown downshift even if you wanted to stay in the higher gear through a corner. I find it very annoying. I expect the 718 GTS behaves the same..
#32
This is the "kickdown". Actual the "button" at the bottom of the throttle is to add resistance. The kickdown is primarily based on the throttle position sensor and available RPMs. I've experienced this with my previous 09 Boxster PDK with added Sport/Sport+ and 2103 Boxster S PDK with SC. If you floor the throttle it will activate "kickdown" if there are revs available. There are two places at Summit Point that are right on the edge of two gears, one is 2-3-2 the other is 3-4-3. Normally the PDK will down shift based on speed and other factors, however if I carry a little more speed it stays in the higher gear and if I'm too aggressive on exit with the throttle it will kickdown. You can manually downshift but only if there are available RPMs. The "kickdown" will also upshift when in manual mode at redline. There is an explanation of "kickdown" in the Owner's Manual.
The Cobb PDK tune eliminates "kickdown" Also read somewhere that the GT3 and GT4 disable kickdown in Sport+ or equivalent. There are other threads on disabling kickdown. One replaces the resistance button with a solid button preventing the throttle position sensor from reaching "kickdown".
