Quickjack alternative for GT4
to get car on SUV adapter you need to lift with quickjack, put half a raceramp, lower, relift with both quickjack blocks, then install both half of racersmps, lower car on raceramps and relift wirh SUV adapter. Reverse order to lower. Looks complicated but takes maybe 4-5 min to do.
McMGC (10-22-2020)
Here are some pictures of clearance for QJ7000SLX model for those interested.
The big blocks (3 inches) does not clear but the small blocks (2 inches) clears fine!
The following 6 users liked this post by kart125:
abqautoxer (10-26-2020),
alwaysdriving (03-18-2021),
CaymanMatt (10-26-2020),
McMGC (10-26-2020),
porscheflat6 (10-28-2020),
and 1 others liked this post.
CaymanMatt (10-28-2020)
I have a two-post lift (and a 4-poster). I need a little bit of extra height to get the Spyder on it so I use these:
https://www.summitracing.com/parts/r...9-v2?rrec=true
They are inexpensive and work great. I've had them for many years (bought them for my 13 981S)
Someone mentioned you couldn't remove the rear under cover with the liftbars, is that an issue with Quickjack as well? I mainly want to be able to change the oil on my 718 Cayman. I have a T which has the 20mm drop like the GTS but not as much as the GT4.
