718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Afternarket wheel choices for GT4?
Old 09-30-2020 | 07:37 PM
Westcoast's Avatar
Westcoast
Originally Posted by electron mike
Thanks for the heads up on the TPMS sensors. Do you have the part numbers/description for the correct ones? I ordered a second set of wheels and want to make sure the sensors they install are correct.
There are two HUF sensors that I know will work for a 2020 718, the first is specific OEM part: 9A790727502 which translates to RDE047V21, the other is HUF BHsens Intellisens UVS4040 which is a programable unit that get set up before it is shipped to you.
A 2016 GT4 would use a RDE048V21 and will not work with a 2020 718, if you search on Tire Rack for wheels for a 2020 GT4/Spyder you will not be shown the Forged One series as they have not verified fitment, but they do fit. If you order a wheel/tire set based on the 2016 GT4 and don't correct the TPMS sensor selection (which is automatic) you will get sensors for a 2016 car.
From TR, this is the correct one for a 2020 718 GT4/Spyder:
https://www.tirerack.com/tpms/detail...0&autoModClar=
HTH
Last edited by Westcoast; 09-30-2020 at 07:57 PM. Reason: add TPMS link for Tire Rack
Old 09-30-2020 | 10:29 PM
ForeverCar's Avatar
ForeverCar
Originally Posted by Xisthos
I had a set of custom RT88’s made by BBS. It uses the LM lip with the E88 center.
Do you have PCCB? Can you share specs on these wheels please?
Old 09-30-2020 | 11:22 PM
electron mike's Avatar
electron mike
HTH
Thanks!
Old 09-30-2020 | 11:53 PM
Noble.X's Avatar
Noble.X
2nd Gear
You may want to check the custom forged to fit your GT4 best.
Old 10-01-2020 | 12:10 AM
SupremePower's Avatar
SupremePower
Basic Sponsor
Originally Posted by Rohan Batra
Anyone purchased aftermarket wheels for the car? Seems like the choices are very limited. Curious to know what aftermarket choices folks have gone with, ideally something solid quality and not too expensive for a winter wheel/tire set
We have a few choices available for your GT4!
I was going to send you a private message but it wouldn’t let me. Please shoot me an email at eric@supremepower.com and I could go over a bunch of options with you!
SupremePOWER Inc
1562 Kimberly Ave - Fullerton CA 92831
Contact: sales@supremepower.com - Shop# (714)632-1951
World's Largest Retailer/Distributor of BBS Motorsport & Street Wheels from 2015-2023
Huge Inventory: BBS, Kline, Brembo, Soul, Recaro, KW, Akrapovic & 200+ brands. Installation available
** Retail & Wholesale ** Global Delivery ** We match/beat any authorized dealer's price **
SupremePower.com // SupremeForged.com // Follow SupremePower on IG
Old 10-01-2020 | 01:33 PM
Sean in Texas's Avatar
Sean in Texas
Yep, Forged One FF10's from Tire Rack, but what I did was to make these my summer set with the Maxx Race 2 tires and install RE980AS on the OEM set for the rest of the year. Watch out for the TPMS sensors though they are still 433 MHz but not the same as a 981/991...
As for expensive, that is your personal definition, the other wheels mentioned so far are great choices but hardly inexpensive!
You might want to check with the dealership, by VIN. Even within engineering code (981/991/718) the freqs can change. It took me 3 sets of TPMS with my Forgelines before I got the right set on my 991. That was a PITA.
Old 10-01-2020 | 01:55 PM
sobiloff's Avatar
sobiloff
Many sensors these days are programmable and handle both frequencies. At work (treadconnection.com) I use the Autel ones and program them for the specific vehicle via a hand-held programmer. Any decent tire shop should have the same capability.
Old 10-01-2020 | 05:08 PM
Westcoast's Avatar
Westcoast
I have had the experience that looking up by VIN did not provide accurate information as to a part or configuration on the car, the most recent being the exhaust bracket, by VIN it shows my car has the full bracket, in actuality only the rear center muffler is attached, not the GPF cannister.
Although my dealer did not have the ability to 'program' a sensor they do have the handheld tool (Wurth) that when set to the year make and model could tell you if the sensor in hand was compatible. This would save you from mounting a set of tires with the wrong one, unless of course the supplier was adamant it was correct and you made the mistake of believing them... Hence my new found level of knowledge about TPMS sensors!
Old 10-01-2020 | 05:12 PM
Sleepy996's Avatar
Sleepy996
HRE or Volk look awesome on the GT4. Goodluck
WheelsB (10-01-2020)
Old 10-01-2020 | 05:19 PM
VVG's Avatar
VVG
Originally Posted by 911F1
How about a set of second hand stock rims? Keep the OE look and probably by far the cheapest route.
The OE wheels look great, but if you are going to spend the money on a second set of wheels, why not get something significantly lighter? The OE wheels are not anchors, but we can certainly do better. 6-7 lbs per corner reduction in rotating unsprung mass will improve ride, make the steering feel a sharper and make the car feel more nimble. Now....the car is so good already that you are well into diminishing returns territory in terms of the benefits of these mods, but if you have decided to spend the money, might as well get something that will at least make some difference.
The following 3 users liked this post by VVG:
wcw67 (10-03-2020), Westcoast (10-01-2020), WheelsB (10-01-2020)
Old 10-02-2020 | 01:26 AM
Alan C.'s Avatar
Alan C.
I have a set of Forgeline GX3s from my GT4. Used the for about 3000 miles before switching to a set of their CF wheels. $1500 for the set plus shipping. No dings, dents or scratches. The centers can be painted in any color you want.
Front 20x9 ET52. Rear 20x11. ET50
Quick Reply: Afternarket wheel choices for GT4?
