Let's talk about cheap exhaust valve mod options!
#301
Dumb question but if you wire the valves open permanently, does the PSE button do anything any more? If the valves are wired open, and you turn off PSE, is the exhaust quieter? My concern would be with the valves wired open that you are stuck with loud all the time (which I assume you are), with zero ability to lower the volume.
#302
#303
The yes the exhaust is louder at normal driving RPMs regardless of the button setting, but if you have the factory exhaust that really isn't terribly loud. I'm not a loud exhaust guy myself anymore, but I do like the richer exhaust sound in mid-RPMs the collar approach brings. I think that 95% of people will find the volume not improperly loud. If you have an aftermarket component in the exhaust then that may be a different thing.
To me the simplicity, cost, and effectiveness of the collar solution outweighed having to open the engine compartment to install other switching solutions and dealing with the remote switches for those. I'd used those on a couple of my earlier 911s and found I was just leaving them set to open almost all of the time anyway.
The following 2 users liked this post by StormRune:
981KMAN (06-22-2022),
StilettoPat (06-22-2022)
#304
.......... To me the simplicity, cost, and effectiveness of the collar solution outweighed having to open the engine compartment to install other switching solutions and dealing with the remote switches for those. I'd used those on a couple of my earlier 911s and found I was just leaving them set to open almost all of the time anyway.
StormRune (06-23-2022)
#305
Well, not really..... With the Collar Option you can adjust the Exhaust Valve Closed Position, from Fully Closed to fully Open, depending on where you place the Collar on the shaft. Thus you do not have to fully disable the system, and can get the volume level you desire, and reduce the Mid-RPM Drone.
#306
Then why did you include the Collar Modification ("collars") in your reply if the question was regarding only "wiring the valves open"?
#307
I was simply pointing out that the Collar Mod is adjustable, and does not render the PSA system totally inoperable. or "Open all the time".
#308
I took the split collar approach that is mentioned in the pinned “popular reply,” however since the linked Amazon product was out of stock and most of the other options were measured in inches and not mm (!), I ended up ordering from Grainger at this link. 2 are needed. Installation was easy once I figured out the best angle to tighten from with the car on the ground. 5 minutes on/off now.
I did go ahead and order the Soul Valve Controller and Akra OAP, but good to have this (adjustable) option if people don’t want to go that route.
#309
I said I was probably going to remove mine but I ended up leaving the collars on my car at a recent track day with my JCR silenced exhaust and am happy to report I passed the static noise test. Happy times.
I've grown to really like this mod with the JCR system. It might not be as dramatic a difference as with the OEM back box but it's good to have a bit more noise below 5000RPM and avoid the abrupt change in volume you get when they suddenly open at 5000. Drone levels are the same but its actually nicer to the ear as there is actually some volume to accompany the 2000RPM drone.
#310
Just installed these collars and I'm satisfied with the result. Not perfect, but just a little bit of growl where there previously was none. Set mine at the 18mm recommended by someone here and I'll leave them there.
One installation tip I would offer is to use a piece of masking tape to keep the two pieces together on one side as you go to install the collar on the shaft. Keeps the parts aligned correctly, making the insertion of the first screw easier. Once that first screw is in a couple threads, the other goes in like butter.
I did have to try a few different orientations of the collar to prevent it from contacting the vacuum valve bolts since the rod pivots slightly and doesn't go straight into the valve as it is actuating. YMMV.
981KMAN (06-25-2022)
#312
Well, to be precise the presence of the collar does entirely prevent full closure so it is "open" all the time, albeit not fully open depending on where you set the collar.
981KMAN (06-26-2022)
#314
#315
Picked up the car on Monday, only have time to put 100KM on the car so far, but I did the 10 minutes Collar Mode... real easy... Haven't driven it yet....dinner time.... but I am sure it will be awesome
I marked the open and close position with a blue marker. I think I positioned the collar at about 33% open all the time
The following 2 users liked this post by lowbee:
downshifted (02-18-2024),
slilley (07-02-2022)
