Got one of those lightweight antigravity batteries for my 718 Spyder
Originally Posted by Antigravity
First we would never not answer any question or put you down for asking anything.... even if I've written about it 20 times already. The point here honestly is to educate, this is still a newer technology that people have questions about. It our job to make sure to answer honestly.
a) Any fire risks above normal batteries?
Actually no, there is not more risk with this battery than with Lead/Acid. This is due to the fact that our batteries incorporate what is know as a BMS (Battery Management System) inside the battery. It is a circuit board that controls the the battery and keep it operating within certain parameters only. For example if an external source such as the alternator breaks and start spiking voltage to our battery the BMS will cut off those higher voltages and not allow them to reach the lithium battery inside. Another example is over-discharge, our Battery will actually put itself into a sleep mode before it can be over discharged and damaged. In the older, or in some current brands they lack a BMS, that is what is dangerous because then the batteries can be subjected to circumstances that call allow the battery to over-heat and go into what is called Thermal Runaway. And while the Lifepo4 chemistry in most every case will not go into an open flame it will over heat and melt the plastic and damage surrounding areas. But. this is in batteries without a BMS and that subjected to extreme conditions outside their operating parameters, but our units all have a full BMS in place. So in effect the battery operates only within a set of parameters that won't allow dangerous occurrences to affect the battery. Our batteries also have flame and heat proof materials surrounding them inside the battery itself.
b) Can it handle not being on a tender for 5 months?
This is tougher to answer because that depends on the level of parasitic draw from your particular Car. First, yes, it could handle not being on a battery tender for 6 months if it was NOT connected to the Car, meaning if you disconnected the battery during storage, and this is because lithium has a very low self-discharge rate. But in the Car you would be hard pushed to get 5 months out of it unless you went for our 60 Amp Hour Option and your car had a very low Parasitic Draw. Keep in mind I have in fact gotten 7 weeks from a 24 Amp Hour unit in my 991.1 GT3RS, but that car has a very low parasitic draw on it when it goes into full sleep mode. So I think a 60Ah could do close to 5 months. But again this depends if you have extra accessories and cars level of draw on the battery when in storage... but 3 and 4 months can be done.
c) How is this different from the Porsche Li-Ion battery that was offered and discontinued?
Being blunt, which I tend to be.... those original Porsche Lithium Batteries really were bad batteries. Their failure rate was abysmal with over 50% failures. I don't know the exact reason but we can assume it was the BMS system was faulty and allowed the battery to over-discharge to much. As far as differences, we just have a more advanced BMS, and a top quality Lithium Cell. But Porsche has a new Lithium Battery that should be good, it comes with some of the new cars. The only problem with the new cars using it is that it is a proprietary battery at this point in time so you cannot just exchange it for another battery since it has a communication port that speaks to the LIN system in the Car. So hopefully those should be lasting at least 7 years or Porsche owners are going to be getting the short end of the stick since that new Lithium is proprietary and you will have to pay whatever they want to charge for it when it dies.
Intriguing option for a few cars. I think what brought me back to your batteries is the jump start feature because this year I will be parking one car off site in the winter, no tender. Would there be enough juice for a jump in the spring if needed? 997.2
Thanks for the response.
Do Lithium-Ion batteries play well with the latest Porsche Auto-Stop/Start technology on the 718 GT4/Spyder?
Does the car need to be programed to know it has a Lithium-ion battery installed to replace a AGM unit?
Considering Auto Stop/Start which battery would be recommended 40Ah or 60Ah?
The main issue we have encountered when any Porsche throws a flag has been the Porsche's that are actually putting out over-charge levels of voltages and that was corrected by some changes in our BMS that allowed more leeway in Cars that spiked over 15v. But we have never found any of the Cars while in Start/Stop to be allowing TOO MUCH over-discharge.... the only Car we found doing that was the Ford Mustangs that were sometimes allowing the voltage of the battery to drop below 12v.... and that is not normal since a Lead Acid battery is considered deeply over discharged even at 12.2v.
Last to get to the bottom line. in any of the Start/Stop applications.... more Amp Hours is ALWAY best. This just allows the system to work a bit better since you have a lot of extra capacity.... so the Car will not often be starved for Capacity.
Westcoast (09-21-2020)
Great thread, and thanks for your explanations. A question:
If the battery puts itself into sleep mode below a certain charge, then wouldn't that disconnect it from all parasitic draws just as if it was physically disconnected from the car, thus preserving its starting power for much longer?
Do you have a decision matrix for choosing the appropriate (the lightest but still functional) battery model according to car model/year and intended use (daily, backroads, weekends, etc.)? I'm considering this when I need new batteries for my 996 GT3 and my 987 Boxster S, both 2005 models for backroads/weekend use, and mostly stored in winter. Also for the Boxster GTS 4.0 that I plan to get next year.
Yes, the battery puts itself to sleep and prevents further discharge of the battery, so no parasitic drains would NOT effect it, the car would actually be turned-off at that point. But keep in mind the battery is in a severe state of over-discharge to have gotten to the point of going into sleep mode. So it is at the bottom of its state of charge and Capacity, and even though turned-off and in sleep mode, it can only last a certain amount of time longer in that state and not be completely dead itself. For example after maybe a month or max 2 months in sleep mode will it still easily start the car, you don't really want to wait more than a few weeks to start it again after it enters sleep mode..
The RE-START is meant as an emergency function, and not as a replacement for typical battery maintenance. So yes it can even start the care a month or even more later... but that is not how we intended it to be used. We expect someone to come back to it within a month and start the car.
If you watch the video at the point that lovetoturn put that is a area where I go into that. But I can also try to answer here if that does not answer you question.
But in general the 40Ah is the main streetable battery that a sports car would need. It can sit usually for about 6- 8 weeks in most cars without needing a charge.... this depends on the level of parasitic drain on any individual vehicle. Then the 24ah is only for Track unless you want to keep it on a charge and be more involved in its maintenance... which we don't suggest at all. The the 60Ah is the best if you just want to have a car that can sit a long time without driving much and not needing to be on a charger ever, or if you are in colder weather.
I have one more question about the AntiGravity batteries. I recently installed the Group 48, 60AH AntiGravity battery into my 2014 Cayman S. I coded the CS ECU to indicate a Lithium Battery has been installed. Yesterday the weather here was cool when I took a long drive. Outside air temps were in the low 40's. During that drive I noticed that the alternator was charging in the neighborhood of 14,6 to 14.9 volts. The battery was on a Lithium Battery Maintainer for several days and indicated the battery was fully charged prior to driving. My question is will the AntiGravity lithium battery be damaged by those level of charging voltages? Also , after the OAT warmed up to temps in the 60's (F) later in the day the charging voltage was in the typical 14.2 to 14.5V range. Just curious!!!
No it will not...that still fits well withing the parameters for the battery's management system..what is curious though is that the "lithium" setting generally lowers the voltage output from what we've understood and received feedback on from Porsche so I'm wondering if that program took and saved or defaulted back to a lead/acid profile?
When I installed the AntiGravity Lithium battery I used the ICARSoft Por V2.0 OBD reader tool to indicate that the new battery was indeed lithium and also inserted the serial number as requested . However, the Porsche Cayman did not recognize the numbers off of the AntiGravity battery for the update. As others have recommended on this Forum, I used the serial # from the old Porsche battery that I replaced with the AntiGravity battery. The OBD battery update process then was accepted so I believe it now believes a lithium battery is installed. I was curious as well why the charging voltages seem to be the same as with the standard factory AGM battery. I'm not sure how to tell if the programming I did with the ICARSoft OBD tool actually was accepted by the DME or defaulted back to the lead/acid profile. I'll probably play around with it again but , if as you said, the AntiGravity battery will not be harmed by those voltage levels, I won't be in any rush and will continue to enjoy this amazing machine.
1- You never want to change to the Lithium Setting in the Car initially. There is absolutely no need to UNLESS it is a dedicated Track ONLY Car. The only thing the Lithium setting does in PIWISA is lower the overall output of the alternator to a LOWER VOLTAGE which aids a Track Car which is running topped-out at RPM limits. I creates a minor bit of less drag on the Motor. You will not benefit at all from this on the street and it keeps the battery in a lower state of charge than we prefer since it only goes to 13.8v, and we want to see the Battery getting a full charge in the mid to upper 14 ranges.
2- Secondly you want a base line for the Car... you don't want to go and change settings when just installing the battery, its actually is a PLUG AND PLAY Battery replacement for lead/acid battery. You will not have to mess around, or change settings. It's a simple swap with NO CODING needed. If you start changing setting before you have installed or during install of the battery you have just eliminated the baseline of making sure the battery works as it was shipped to you. If you have any issues with the initial installation at all, then you know you have not changed anything in the car and any issue is very easy to track when you talk to us... but if you changed stuff for the install then we can't assist as well because there were changes to the cars computer, and sometimes you can't go back to the baseline. I don't want to be a broken record but for 99% of the Customers its simply a directly swap out the battery then go driving.
The following 3 users liked this post by Antigravity:
Very interesting! Well so far the highest voltage I have seen was 14.8 t0 14.9 V when the OAT was about 39F. Glad to now understand why Porsche is forcing the alternator output to climb during cold weather. Makes sense. But also glad that your BMS can handle that without any negative effects on the battery cells. Good Job on that design.
Thanks again for taking time to answer my questions.
Nick
Nick
This is a very well conceived and sorted product. From the recharge fobs to the battery status app. Well done across the board. If this holds up well through the winter and the the limited driving that occurs during that time it will be my first purchase for future Porsches.
i wonder if the techs at Porsche changed the Lead/Lithium settings when they installed my battery.
