Shift linkage problem.
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
Today i lost R-1-3-5 gears when was doing track day... I was lucky that there was a guy who have Clubsport with his mechanic, so his mechanic inspected the car and find out straight away that shift linkage on the left side of the gearbox failed... He managed to fix it quite fast, so i was able to do a few hours more on the track. But on the way home this happened again.
Tomorrow i will bring car to the dealer, car is 9 months old and done 10000 km (+-2000 km on track).
The mechanic also said that probably clutch bearing needs to be inspected also, as he heard a strange sound when clutch disenagaged...
Someone had similar issues? How long the clutch need to last on 718?
I had one very bad accident with clutch when i get stuck on the ramp when tried to enter hotel parking, the angle between ramp/floor was to big, so i can't enter the garage and i had to drive back. This ramp was made from concrete with quite a big angle, so i had to use my clutch to go up, it slipped a bit, was burning clutch smell and etc. Does such one accident can destroy the clutch?
And the clutch problem can be connected with shift linkage problem?
Tomorrow i will have to discuss this with dealer, regarding warranty...
I am thinking your track days are pretty hard on the clutch that can lead to problems. I doubt one instance of slipping the clutch will do it.
There was another report of people having linkage issues on here IIRC.
My brand new car has a distinct tick with the clutch disengaged. I am wondering if it's an issue or just a symptom of these cars and the noises they make. Could be related to the dual mass flywheel?
While not likely, you absolutely can fry a clutch with one really bad 'riding the clutch' situation. Obviously unrelated to the linkage situation.
Today the car was inspected at delaer, so they said that they didn't noticed any problems with clutch... So they give me some hope ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
The linkage will be repaired under warranty, they will change a shifter cable. They said they never heard that it happened to someone before, so they said that probably this was just bad luck.
I tried to search the forum, but all what i found is that only in older generations caymans this was a common problem...
Now the most important thing for me is that it was fixed till Saturday, another track day is on my calendar
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Is this on a 718 GT4?
Great to discover problems like these under warranty. How confident are you about your manual shifting technique at the track? Not suggesting you're doing anything wrong but would be nice to have it confirmed by someone else sitting in your car as you do a lap.
Yes, 718 GT4
This was the first thing what i was thinking also, that this can be a problem of my shifting technique, as i am started to go to the track only from this Febuarary.... I already done 6 or 7 track days. I drove only automatic cars for years before GT4... As i was completely new to driving on a track, i am always been driving with instructor for at least half of track day. Nobody said that i am doing something wrong with shifting.
I uploaded some videos.
DFW01TT (09-01-2020)
Now the most important thing for me is that it was fixed till Saturday, another track day is on my calendar![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Yes, 718 GT4
https://www.youtube.com/watch?v=U6uwx9dfqTw
https://www.youtube.com/watch?v=qroYI8iLWJg
I had a guffaw with my old 981 6-speed on a road trip once, stopped at a light on the hill with lots of traffic and a short duration turn light, the light went green and I was in second IIRC, no time to correct I pulled away and yep you could smell the burnt clutch... it was never the same again, slipped in 3rd when floored.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
I posted that I had the exact same problem just three days ago. I am not an expert mechanic or even really much of an amateur compared with most on this board but it is not a clutch problem. It is a problem with the cheap plastic clips with which Porsche attaches the shifter cables to the transmission that can easily break or come loose. The answer as far as I can tell is more robust aftermarket hardware. It seems like track usage would be a classic scenario where this would occur even with perfect shifting. Doing a small amount of internet research showed that unfortunately this is a common problem in multiple Porsche manual transmissions.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/352f5d86_9e7f_4ca1_8dd6_b9450857bc68_53d097510fd204ed1485c4d49b49381686da1fcb.jpeg)
This is a picture that I did not take but stole from another thread in another forum to show the zip tied connection that fails.
