Rattling under acceleration near right rear wheel
Guys,
just starting to happen, when I push I hear some rattling issues, its around right rear wheel.. Its new sound, didnt hear it before and its pretty annoying
I have around 5k km only, sounds a little bit like plastic.. when i stop accelerating, sound is gone.. it doesnt matter if im accelerating from right/left curve or its on straight road, but need to really push, slow acceleration is ok
setup and everything is stock (except aero)
Roarke
Roarke
Not sure if it's the same, but I have noticed a sound like a throw-out bearing at idle, which stays until about 3500 rpm, and then it goes away. I've had this since delivery. Has not impacted drive-ability at all.
Guys,
Roarke
Roarke
under the car in that area. maybe something is hanging.
I have something similar from the right rear. Sounds like a ticking. It isn't constant.
Once had this and it was simply a screw in the tire. Haven't checked my tire yet.
I had a metallic rattling sound emanating from the driver’s side rear wheel. Turn out the vacuum line for the exhaust valve came off because I didn’t push it back on far enough after testing out the exhaust without the vacuum lines attached. Reattached and all is good.
Thank you guys for all ideas... Im going to visit dealer tomorrow and let you know..
