Tire Pressure
I think 2.3/2.6 (bar, f/r) hot is good for street driving. Its 33/38 psi. Good compromise between grip & wear. More presssure and it gets slippery, less pressure and the car feels less responsive and you can feel some tyre rollover on the front even with +10° caster and -2° camber.
I obtain that pressure with 2.05 and 2.3 bar cold which is 30/33 psi I think.
Received 1,679 Likes
and the recommended fills of 29psi/front and 33psi/rear, GT cars wouldn't run in comfort mode...
I was full day on track and it was a little bit hot, i deflated tires several times and keep the door pressure (2.0/2.3) and looks like tires were very hot still.. maybe i was pushing too much or did something really bad with my driving style...Dunlops...
Most notable is what looks like a clean area on the inside band of the tires? That would indicate an area that is not getting a lot of contact and would benefit from a camber adjustment.
They're going to be hot at the track, so the way they look is normal there (a little bit of a melted look).
and yes, fully stock setup now.. will be changed next week for next track day
The pressures on the door are good for setting cold pressures when you're just driving on the street. On track, all bets are off. They're not a horrible place to start if you have no idea where to start for the track, but they will almost always lead to pressures that are too high (ideally you'd make one or two mid-session adjustments in the first session of the day). And if you had to err one way or another, I'd rather start at the door pressures than taking a bunch of air out and possibly risking the integrity of the tire because of under inflation.
Also, a tracked tire should look completely scorched across the surface; how "melted" the tire looks is not an indicator of optimal or sub-optimal pressure.
The following 3 users liked this post by SnoBdrAK:
Originally Posted by Flat6MT
waiiiit a second, there's a track mode for the TPMS in the GT3/4 etc. ? did not know that.
Full disclosure: I have not tried it with the 718 GT4 yet, but I'm not holding my breath it'll be substantiately different.
There is, but the only thing it really does is allow the cold pressures to go lower before the car complains. If it actually disabled all TPMS warnings or something, it might be useful. But if you're still "too low", even with circuit pressures selected, the car still sets of warnings (sometimes even in the middle of the session once your pressures are well above where they were at the start).
