718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
« Driving on the race circuit » brochure
Old 07-06-2021 | 12:16 PM
jmartpr's Avatar
jmartpr
I was advise when I had the 981 that when running Slicks (I use Pirelli DHs) to make sure the oil level is at the very maximum level allowed......did numerous track days and never had a problem, but I guess it also depends on the track design.
Old 07-06-2021 | 12:37 PM
Dr.Bill's Avatar
Dr.Bill
Ask your dealer for the brochure. It should have been delivered with the car.
Old 01-20-2022 | 06:56 PM
Fast-Eddie's Avatar
Fast-Eddie
Attached below is a scanned copy of the "718 Cayman GT4 - Driving on the Race Circuit" brochure. (low resolution scan, so quality is pretty bad)
The following 2 users liked this post by Fast-Eddie:
Jim Rockford (01-20-2022), Zhao (01-20-2022)
Old 01-20-2022 | 07:02 PM
Larry Cable's Avatar
Larry Cable
Originally Posted by GrantG
I miss driving at Spa - great track. Out of curiosity, did they ever find something loose or another issue from tracking?
Old 01-20-2022 | 07:47 PM
Zhao's Avatar
Zhao
cool thx for that
Old 01-21-2022 | 08:08 PM
phefner's Avatar
phefner
For me, only thing my post inspections ever found were some zip ties missing on the brake ducts. Simple replacement. The cooling holes in the brake rotors should always be cleared too. Mine would accumulate some matter after a track event.
Old 03-31-2022 | 02:20 PM
reelbuddies's Avatar
reelbuddies
Excellent thread guys. Appreciate the person who posted the "Driving on the race circuit pamphlet".
I plan on adding 7mm shims to my lower control arms this weekend to gain a little more negative camber. I bought the shims from Seacoast however do I also need to order longer bolts?
Also, I add the additional shim to combine it with the shim that is already there ..correct? Finally, I've read a lot about torque, how should much should those 2 bolts be torqued to. Thanks in advance for a newbie.
Old 03-31-2022 | 07:59 PM
Bill Lehman's Avatar
Bill Lehman
You are clueless. Get a shop to do the work. For starters, changing camber requires adjusting toe.
Old 03-31-2022 | 08:18 PM
reelbuddies
you’re so smart. Thank you!
Quick Reply: « Driving on the race circuit » brochure
