718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Brake Pad/Rotor Alternatives
Old 04-26-2021, 01:06 PM
DFW01TT
DFW01TT's Avatar
Originally Posted by DMFOrlando
Hi...just saw your post while researching a bit. Have a 718 spyder with brakes that are making a good bit of noise. Did you find a way to resolve the issue on your end? Did these pads work?
Key response from above:
Originally Posted by Sean in Texas
Not much you can do about dust, but the noise...I have no idea how many miles are on your car, so bear with me. Have you actually bedded the brakes? Or have you just been toodling around town?
I bedded mine right after delivery and never heard a squeak.
Old 04-26-2021, 01:12 PM
DMFOrlando
DMFOrlando's Avatar
Thanks for the thoughts!
Old 04-26-2021, 01:16 PM
DMFOrlando
DMFOrlando's Avatar
4350 miles roughly and they have been bedded in properly. It's maddening.
DFW01TT (04-26-2021)
Old 04-26-2021, 06:49 PM
Jim Rockford
Jim Rockford's Avatar
Originally Posted by DocMo
Another interesting pad from Endless.
Any experience?
I like how that spider chart goes right to the edge almost in all criteria. Zero compromises!
And don't forget... Challenge to the Future!
Old 04-26-2021, 09:13 PM
Hmet
Hmet's Avatar
I went with the surface transform solution. I had steel OEM and ST have s seemless modification kit that does not require change of caliper. It feels like a significant upgrade with the following benefits that i noticed :
1- i can feel the reduction of the unsprung resulting in a much better suspension compliant feeling and the maneuverability of the car (street driving) feels a lot more agile. I would say this is the biggest benefit even though the initial motivation was to deal with brake dust.
2- the brake dust problem is gone. I would say more than 80 precent reduction in dust that i observe on the wheel.
3- a better breaking feeling (more reassured). But this can be more subjective. I had no issue with steel breaking performance.
The bedding process required a good 45 munites to an hour drive.
4- installation was straight forward. You just need to insert the spacers plus changing the brake line in the front set. All supplied with the kit.
5- the disks look much nicer than the original rust prone steel rotors.
I highly recommend them if you are willing to make that kind of investment.
Hope that helps
mprog (04-26-2021)
Old 04-27-2021, 11:12 PM
JC68
JC68's Avatar
I use Carbotech 1521 on my street car, they are low dust. The Endless pad above seems good, I haven’t used it. I’m using Endless MX72 for my other street/track car. PCCB is best low dust and performance.
Old 04-28-2021, 04:32 AM
Reedy
Reedy's Avatar
Received 1,089 Likes on 477 Posts
I use Carbotech XP10 for my track car and have used 1521's. The XP10 are the best street/track day brake pads i've ever used by a mile. I didn't think they're available for these cars tho?
Old 04-28-2021, 08:45 AM
JC68
JC68's Avatar
Carbotech are made to order. You can always send them your oem pads and they will put on the compound you want. Or order for the 991 gt3 on the website since it’s the same caliper. I’ve used XP10 for track, how are they in terms of dust and noise for the street?
Old 04-28-2021, 10:11 AM
Reedy
Reedy's Avatar
They are very dusty and fairly noisy. Not ideal for a street pad but they work right from cold and give the most consistent pedal feel at the track that I have found in my current car. The Cayman should work even better with XP10 at the track because the brakes should run cooler than my Mazda3 MPS does.
Old 04-28-2021, 10:20 AM
Reedy
Reedy's Avatar
Oops double post.
Old 05-01-2023, 09:48 PM
simhoppm
simhoppm's Avatar
it seems Dixcel packages 2 pads per box, not 4 pads as most companies do.
was that the case?
I want to replace my pads because they are creating so much dust, and Akebono doesn't seem to make any pads for Porsche.
Quick Reply: Brake Pad/Rotor Alternatives
