718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
718 GT4/Spyder oil change procedure?
Old 08-29-2020, 10:53 PM
  #31
venom51
venom51's Avatar
There are multiple ways to do it. You can pour in just shy of the recommend oil change refill callout. Go run the car until the oil is up to temperature then park it so that the DME will provide the information to the dash and adjust as needed.
You can use a scan tool capable of reading the sensor in real time, check it before you empty the pan and record the value. Change the oil and refill to that value. A tool capable of a real time reading may not be economically viable to some. You would still need a tool to reset the service interval anyway however. Those capable of that aren't terribly exspensive.
Old 08-30-2020, 12:11 AM
  #32
TurboCup87
TurboCup87's Avatar
Summit has Mobil 1 ESP 0W-40 in stock
Old 08-30-2020, 12:23 AM
  #33
m3bs
m3bs's Avatar
That is the oil I use in my ZL1 for the street. It is not the correct oil for the 718 GT4.
Old 08-30-2020, 12:30 AM
  #34
TurboCup87
TurboCup87's Avatar
it says that it’s for GPF cars... Porsche C40 spec according to Mobil 1 web page
Old 08-30-2020, 12:44 AM
  #35
TurboCup87
TurboCup87's Avatar
Old 08-30-2020, 06:11 AM
  #36
arcamalpha
arcamalpha's Avatar
In europe at least, “ESP” and “ESP X3” are two different types.
Old 08-30-2020, 12:14 PM
  #37
m3bs
m3bs's Avatar
They are indeed different, as Mobil 1 tech support will confirm. Only the “X3” version is C40 approved.
Old 08-30-2020, 06:02 PM
  #38
TurboCup87
TurboCup87's Avatar
Crap....guess I’ll have to cancel my order My guess is that with our cars not really having a GPF, we dont really need the C40
Old 08-31-2020, 10:11 AM
  #39
blepski
blepski's Avatar
Check out this thread I started about a month ago. I have yet to get a straight answer on this.
https://rennlist.com/forums/718-gts-...40-or-a40.html
Old 08-31-2020, 12:43 PM
  #40
scooteria681
scooteria681's Avatar
https://rennlist.com/forums/718-gts-...pyder-gt4.html
Old 09-02-2020, 02:10 PM
  #41
Westcoast
Westcoast's Avatar
Received 4,696 Likes on 2,733 Posts
So have we reached a conclusion that the old spec of A40 has now been superseded by C40... if so I need to return a couple of jugs of 0W-40 A40!
Old 09-02-2020, 08:23 PM
  #42
Westcoast
Westcoast's Avatar
Applications
Mobil 1 ESP X3 0W-40 is recommended for high-performance engines requiring GPFs (gasoline particulate filters).
• Mobil 1 ESP X3 0W-40 can only be used in the vehicles for which it is approved. It is not backward compatible with vehicle engines requiring an A40, C30 or C20 . ***
*** Always consult the owner's manual of the vehicle for the manufacturer's recommended viscosity grade and specifications
Old 09-07-2020, 03:34 AM
  #43
Croc999
Croc999's Avatar
Regarding differences between A40 (previous standard) and C40 (for our GPFed cars) - more info here:
https://rennlist.com/forums/718-gts-...l#post16819147
Old 12-02-2020, 02:25 PM
  #44
Benzwiz
Benzwiz's Avatar
So sounds like the oil fill volume is about 8L?
Old 12-02-2020, 02:43 PM
  #45
s2kspyder
s2kspyder's Avatar
I read 7.5L online which was a starting point for me but after topping off in 300ml increments, I was able to get closer to 8.5L in there. I hate how there is no dipstick. I had to go drive the car and measure it via the computer. BMW has the same system but when I added 6.5L, the green bar was exactly at the top. I wonder how accurate the reading is....
Quick Reply: 718 GT4/Spyder oil change procedure?
