How many years should the plastic window last on the Spyder?
Somewhat serious question...can the top be stored down for long periods of time? I'd imagine the owner's manual mentions something about this, and in theory it would be nice to keep the top down while in the garage (maybe with a dust cover?), but I can't help but think wrinkles or marks could form long-term unless it's pretty rugged.
The Spyder's plastic window will be fine. It folds flat when you lower the top. Doesn't get scratched after being laid down. In almost 5 years of usage (981), not a single problem. Visibility is fine as well. It's a brilliant shape, matching the inside rear mirror; the entire mirror's view is covered! Since it gets laid flat, one could theoretically replace it with a glass window. But, I wouldn't worry about it. In my view, they could have tried harder to make the top even lighter along the lines of 987 gen, but simpler.
The 986's plastic window used to get fogged on the inside from some sort of mist from the engine; don't remember what it was. I used Plexus to wipe off periodically. I don't think it ever got dull or turned yellowish.
Gatch (07-05-2020)
With all the regulations and mandates on car safety equipment, it’s pretty hard to believe that a rear window defogger isn’t required.
Also, while it’s good to hear that the plastic doesn’t seem to be prone to yellowing, I can’t imagine it not being prone to scratching. I think I’d even be afraid to wipe it dry with a microfiber cloth after a washing, let alone trying to remove bird crap, sap, or the like. Granted, with the window being nearly vertical and so small, it’s unlikely for anything much to get on it, but sooner or later, it will happen. And forget about scraping ice if you plan on winter use! I can’t wait for my Spyder to arrive, but the plastic window is really idiotic. It’s also a missed opportunity for Porsche to make another $750 on every Spyder it sells. If a glass rear window with a defogger was an option available for $750, how many would not buy it? It couldn’t possibly add more than 3 lbs to the car. I guess that 18 way seats and the Burmeister system each add about 25 Lbs. Actually, with all those speakers, the Bose and Burmeister must add More than 25 lbs. The weight saving argument for the plastic rear window is 100% BS.
Like all of you I am type-a and sweat the details so as you consider a Spyder I understand your considering every little thing.
Ok, that said, the window is inconsequential. I have not thought about it once in 400 miles.
Don't over think it.
Gatch (07-06-2020)
Agreed with the posters saying not to worry about it.
The window on my 4 year old 981 Spyder has no sign of wear, either scratches or yellowing. It is relatively hard, thick and does not bend. It resembles acrylic. Very different from the thin flexible folding windows you see on most convertibles. I expect other parts of the top to wear before the window does.
Gatch (07-06-2020)
I DO NOT recommend 303 Protectant it will leave behind a non-clear residue!
