718 GTS4.0 lowered, tyre change update settings appeared
Registered User
I just finished installing the techart lowering spring on my GTS4.0 Cayman, after a few miles drive the tyre change update setting appeared. I reset the TPMS then it's gone but I am not sure if it will appear again. I didn't change the tyres or anything so I am curious why would this false code appear? Is this code normal for the lowering spring change for the 718s since I don't have the same false codes with my 991.2 C2S nor my B9 RS5 Sportback? As for other things the ride quality feels almost no difference to me compare to stock (I have SPASM) which is exactly what I wanted and the stance is amzing right now.
Did you happen to switch tires left to right when reinstalling?
gurneyeagle (09-21-2021)
Registered User
Most of our tires have an arrow and "outside" printed on the tires. Not to be rotated or swapped side to side.
