Click/pop/clunk - CTGS
When just getting underway I sometimes get a pop/clunk from an area behind the driver’s seat. I first thought it was the locking mechanism, but I’ve since switched the car to lock at ignition on so that’s not it. It does indeed sound like a locking mechanism. It may be perfectly normal for all I know. Thoughts? thx
EDIT I should note you can actually feel it when it happens. That’s why I was sure it was a locking mechanism slamming shut.
I have a base Cayman with a manual transmission. Some mornings the brake pads will stick to the rotors a bit when I first take off. If I let the parking brake disengage automatically when I set off rather than turning off manually, I will get a bit of a pop/clunk as the pads break free from the rotors.
