718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Brake Pads for auto x / track with stock GTS brakes
Old 10-07-2020 | 01:32 PM
RADONCulous's Avatar
RADONCulous
Default Brake Pads for auto x / track with stock GTS brakes
Plan is to have car ready for AutoX / track. Purchased FVD steel braided brake lines and Castrol SRF. Any recommendations on brake pads that could be used with stock brake set up for the 718 GTS? Or even any brake kits? Thanks.
Old 10-08-2020 | 10:23 AM
PTSFX's Avatar
PTSFX
I use Raybestos ST-43 successfully for the track.
Old 10-08-2020 | 01:32 PM
Todd B's Avatar
Todd B
SRF is a good start for fluid. I find that pads tend to be a personal choice. How much initial bite do you want?
How much heat do you need in them to work optimally (what's good on the track may not be good for a 60 second autox)?
How much noise can you put up with driving on the street? If running on the track, which track? Some tracks are easy on brakes, where as others will eat the pads for lunch.
I like the Ferodo DS-1-11 pads on track, but the squealing on the street can be unbearable. I've also run Pagid Yellow's, they are good and have a good initial bit, but once the pad is down to about 50% left they fad too much on track.
Stock pads are actually good for autox around here. Max speed is ~60. Typical run is 50-60 seconds.
Old 10-08-2020 | 08:22 PM
RADONCulous
Thanks guys!
Old 10-09-2020 | 01:09 AM
b-grif's Avatar
b-grif
I agree with this. AutoX and track are very different. I run pagid rsl29s, but I’m doing high speed track and my car sounds like a damn freight train on the street. The stock pads are actually really good! I’d use them if you don’t know what you want, and aren’t doing too high of a speed all day.
Old 10-09-2020 | 11:27 AM
Quadcammer's Avatar
Quadcammer
usual choice are RS29 pagids or PFC 8s or 11s. some guys run ferodos or others, but pfc and pagid seems to be most common in the paddock. I run pfc and like them.
Old 10-09-2020 | 01:07 PM
Dr.Bill's Avatar
Dr.Bill
Pagid and Ferodo have worked for me.
Call Clark at Apex Performance. He will point you in the right direction.
Old 10-11-2020 | 01:22 AM
abqautoxer's Avatar
abqautoxer
Depends on the track and how you drive. I used Ferodo DS2500 on several cars and recently used it for 3 days at NCM on my GTS plus I autox and drive the car on the street. Does all very well. A harder track on brakes you might want more but IMO its the best pad for all around as they don't squeal for street/autox use like some do that are more track oriented.
Old 10-12-2020 | 12:29 PM
sobiloff's Avatar
sobiloff
Clark at Apex Performance turned me on to the Ferodo DS3.12 pads and I've come to really like them in my CGTS. No squeal on the street, they work great cold (although they do supposedly wear the rotor a bit more than stock pads when run at street temps), and have been bomb-proof during several 100°+ days at Thunderhill. The biggest drawback is the amount of dust they generate.
Old 10-15-2020 | 02:40 AM
David Borden's Avatar
David Borden
I started checking for pads from Hawk and a few others and was shocked that they don't make them for the S / GTS for the front of the the car especially since it is the same pad for ~16-18 911?
Quick Reply: Brake Pads for auto x / track with stock GTS brakes
