718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
2018 / 2019 GTS suspension question
Old Aug 20, 2020 | 12:06 AM
RADONCulous's Avatar
RADONCulous
Default 2018 / 2019 GTS suspension question
I wanted to know if PASM was standard on all cars or an option? I've seen it as an option thats no cost and its also supposed to "lower car 20mm" based upon description; however, a few dealers are telling me that its standard on cars?
Is there anything apart from drop in ride height?
Old Aug 20, 2020 | 02:11 AM
Todd B's Avatar
Todd B
PASM is standard on the GTS.
Sport PASM was an option and lowers the car by 10mm
Here's a thread about PASM vs Sport PASM.
https://rennlist.com/forums/718-foru...m-vs-pasm.html
Old Aug 21, 2020 | 02:54 PM
Dgkli's Avatar
Dgkli
I believe there are 3 718 suspensions from 2017 to current on base/S/GTS/GTS 4.0: standard, PASM and SPASM. Standard comes on base and S, with PASM as an extra-cost option.
On the 2018/2019 718 GTS, PASM is standard and SPASM (sports PASM) is a several hundred dollar option on top of that. On the 2020/2021 GTS 4.0, SPASM is standard and PASM is a no-charge alternative.
PASM lowers suspension by 10mm relative to standard suspension. SPASM lowers suspension by an additional 10mm (20mm relative to standard suspension.)
There are conversations elsewhere about the difference between PASM and SPASM other than the 10mm height differential. I don't know how accurate the posts in those conversations are.
Old Aug 21, 2020 | 04:51 PM
Dr.Bill's Avatar
Dr.Bill
A pity they did away with the X73 sport suspension.
Old Aug 21, 2020 | 04:54 PM
Dgkli's Avatar
Dgkli
I would add that my 2019 BGTS with PASM both rides and handles better than my 2014 BS with standard suspension (also with 20" wheels) did. Noticeably on both counts, for normal daily driving.
Old Aug 21, 2020 | 08:39 PM
donR's Avatar
donR
My understanding is PASM-S is the 718 equivalent to X73? Shorter/stiffer springs and stiffer anti-roll bars. -20mm lower over stock height. -10mm lower over standard PASM.
Old Aug 21, 2020 | 09:10 PM
abqautoxer's Avatar
abqautoxer
Also the 2018-2019 GTS get different sway bars, stiffer than non GTS.
Old Aug 22, 2020 | 11:48 AM
BlueNorther's Avatar
BlueNorther
I don't think so, the SPASM is adaptive, and X73 is "fixed" and going to behave the same way despite changing road conditions.
Old Aug 22, 2020 | 12:49 PM
abqautoxer's Avatar
abqautoxer
I'm actually starting to believe SPASM are using the X73. After another member here had me try to also search and find the SPASM springs, it became clear SPASM either uses the same springs as PASM or uses X73. There is no clear SPASM spring in the parts diagram.
