718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Areas for PPF on 718 Boxster GTS
Old 08-28-2019, 02:06 PM
nicholascanada
nicholascanada's Avatar
Originally Posted by iliveoncaffiene
In my hastily drawn mspaint image:
Yellow is the rear "behind rear wheel"
Red is the "rockers to in front of rear wheel"
Green is the front-end panel.
Red and green follow panel lines and should be able to be tucked.
Yellow isn't really following a panel line at the top (unless you want to go all the way up to the rear taillights which I think is unnecessary)
Thank you! So you would not do the fender area by the gas cap? I was thinking most did that?
Old 08-28-2019, 02:19 PM
iliveoncaffiene
iliveoncaffiene's Avatar
You can? But from what I can see on my car it's not really needed. I don't have any issues there - there's more spots on the mirrors than anything higher up on the front quarter panels.
Old 08-28-2019, 04:00 PM
nicholascanada
OK. I was just thinking though if you don't do that area, then is there not a good gap of paint at risk between hood and headlight area that could get dinged as easily as the hood does? Perhaps I am wrong in my my thinking.
Quick Reply: Areas for PPF on 718 Boxster GTS
