Does the 718 engine control adjust for altitude?
As I said before the acceleration of my 718 coupe seems much better than I would expect from just 300 HP. No doubt the PDK is a big part of that as is the 3200lb curb weight.
Amarillo is at 3,600' elevation and so on a standard day the air in Amarillo is about 90% as dense as air at sea level.. I noticed my other now-gone sports cars (all normally aspirated) had a lot better acceleration in the lowlands than they did in Amarillo. It occurs to me that the electronics could compensate for the lower density air charge in Amarillo by having the turbo increase its output.
Does anybody know if Porsche programmed the 718s' electronics to compensate for higher altitude?
Still absolutely thrilled with my new-to-me 2018 coupe. Got the metal license plate on it, the oil changed and the one year service done. I'm going to run it in autocross Saturday.
Thanks!
Thanks!
Thanks!
Thanks!
So yes, I think it compensates for altitude and depending on year, your NA cars did too. The difference is that a turbo compensates so much better because it's manipulating the air pressure and can just turn up the boost. It may lag a bit more, but it will still get to the same pressure as at sea level. An N/A car does not have that ability
On a standard day the air in Denver has about 75% of the density of the air at sea level.
So a normally aspirated car in Denver won't have nearly the same horsepower as it would at sea level.
But with turbocharging it is possible to have that car make the same horsepower in Denver as in Galveston, Texas, again on a standard day.
But Porsche would have to program the electronics in my 718 for it to make the standard seal level 300 horsepower in Denver, or in Amarillo, as it does in Galveston.
I believe most all of Porsche's current turbocharged cars make nearly the same power in Denver as at sea level. The lag is worse (turbos have to spin faster to develop the same absolute pressure), but they can eventually make all (or nearly all) the power. As you go further up in altitude, most of the turbochargers are not properly sized to continue to make full power (but they still make much higher percentage of full power than NA models).
Porsche tunes their turbocharged models to open the wastegate at a specific absolute pressure, not a set boost amount over the ambient pressure. So, it's possible to offset much of the loss due to altitude.
If the loss in horsepower of a normally aspirated 300 hp car is proportional to air density then the NA car would have, on a standard day, about 225 hp.
If my 718 puts out 300 hp in Denver I would have 75 more hp than the normally aspirated 300 sea-level-horsepower car.
I get your point about it taking the turbos longer to get wound up in Denver than in Galveston.
Very cool never-the-less!
Thanks for all the replies.
AmarilloMike (07-09-2019)
Turbo cars since the 90s have adjusted boost for elevation to a limit. For example, a stock 90s supra could hang with a viper of the same era in Colorado, but not at sea level. The limits to how much boost are knock threshold and turbo speed. All the OEMs have elevation margin built into their turbo sizing. Some leave more margin than others... But as an example, the turbos on the 991.2 have a speed limit in the ballpark of 200k rpm. At sea level, they maybe spin only like 170k rpm. So the Ecu can up the boost/turbo speed by 30k at higher elevations to offset the loss of air density. *note: numbers are for example only, I haven't calculated what the actual turbo speed limits are for the two turbo sizes for the 718 nor speed in operation.
That answered the question I was asking exactly.
Before this thread I did not know it was common practice for manufacturers to "normalize" their turbo cars for altitude.
Thanks again for all the replies.
Best,
Mike
Best,
Mike
https://rennlist.com/forums/991/1150...l#post15968368
A common specification is a turbo must have enough elevation margin to not have to derate power at 2000m. That number does depend on the OEM and the application. In other cases, maybe 1000m, etc.
That is very interesting.
So, if the 6,000 meter rule-of-thumb holds true for the stock 718 it would have the same horsepower in Denver as in Galveston. Quite an advantage for the highlanders I think.
Thanks!
Thanks!
If you drove the same car from Denver to the coast (sea level), your car would have the same power the whole time. The only difference you'd notice is that in Denver the turbo would feel laggier.
At sea-level, the 718 and a 300 hp normally aspirated car have, by definition, equal horsepower.
But if I dyno those same two cars at 5,000' altitude, the 718 still has 300 horsepower while the normally aspirated car is significantly below 300 hp.
So everything else being equal, the 718 has more power than the normally aspirated 300 sea-level-horsepower car when the cars are in Denver.
Assumptions in my statement:
The 718 turbos are capable, on a standard day, of outputting enough volume and pressure at 5,000' to maintain 300 hp.
All dyno tests are done on a standard day.
