718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Suggested ground wire connection for radar detector?
Old 05-24-2019, 07:55 AM
martopoulos
martopoulos's Avatar
Default Suggested ground wire connection for radar detector?
Last night, I hardwired a Valentine V1 to the driver-side fuse box and had trouble finding a bare screw for the ground wire connection. The closest thing I could find was painted (see pic below), which I don't think is gonna do the job. I have since disconnected everything as a precaution. Any suggestions where to connect the ground wire? Or should I try to strip the paint from the thread, etc. in the picture below?
Old 05-24-2019, 11:30 AM
Red991S
Red991S's Avatar
on the passenger side fuse box a few inches forward on the bottom is a bolt you can use.
Old 05-24-2019, 11:32 AM
martopoulos
It's only on the passenger side?
Old 05-24-2019, 11:50 AM
Todd B
Todd B's Avatar
Why not just put a spade on the wire and attach it there? There’s already a connection there, or am I misunderstanding?
LWG (01-21-2023)
Old 05-24-2019, 08:29 PM
martopoulos
(I'm an electrical noob, so my apologies if I'm misunderstanding you here). By "there" do you mean the painted area I've highlighted with the arrow? I actually made the connection shown in the picture; the black wire is the ground wire with a spade/eyelet terminal end. After I made the connection and took the pic, I realized that, hey, a painted thread might kill the conductivity and make the ground wire useless.
Old 05-24-2019, 09:23 PM
martopoulos
Actually, I found Porsche's factory wire grounding when I pulled back the carpet next to the dead pedal. It looks much the same-- painted like the other screw. So maybe they use conductive paint? I would add my wire there, too, but it's super awkward to access that spot. (Though I probably could if I had to).
LWG (01-21-2023)
Old 05-24-2019, 10:18 PM
Todd B
Todd B's Avatar
The paint on the nut isn't an issue, it's just on the outside. Where the spades are bolted in would not be painted. You can also use a small washer with burs on it to dig in. It doesn't take much to get a connection.
A volt meter is handy to verify the voltage and connection. You can grab one for less than $10. If you don't have one in your tool box, I would recommend grabbing one.
Old 05-25-2019, 02:10 AM
martopoulos
IIRC, even the threading was painted, not just the nut; that was why I was concerned. I think the burred washer is a good idea to play it safe, as is a volt meter. Didn't realize they could be bought so inexpensively. Thanks.
Old 01-20-2023, 05:35 PM
Tiger03447
Tiger03447's Avatar
Default Wiring harness
When you go to replace the wires, try to make them all 16 gauge for std wiring. And heavier where it counts like the battery to starter cable. ANYTHING to lessen the load and prevent fires!! ESP. Under the dash!! Just sayin…
Old 01-27-2023, 06:51 PM
Denny Swift
Denny Swift's Avatar
Received 1,479 Likes on 627 Posts
This is what I used (on my 981, my Spyder, my 992 GTS, and my neighbor’s 992 4S). It’s right above the fuse panel.
Edit: I just saw this is a very old post…
Quick Reply: Suggested ground wire connection for radar detector?
