Manthey Racing 718 GTS as a Nurburgring Toy
#46
Impressive!
#47
Great driving Seb against the RS. Is it .1 or .2?
Seems like you are a little faster under breaking and lower speed corners but then the RS is a little faster with the aero on the high speed corners as expected.
Though unexpected is that 718 GTS can keep up with 991 GT3 RS! Would be interesting to see what would happen with an aero kit.
Seb, do you think you are getting much better acceleration/pickup with the BBS Fi-Rs? I am thinking in the 19" you are saving maybe 3kg per corner compared with the OEM wheel which could also account for your extra pace.
Have you thought of installing the larger Girodiscs? Maybe improved braking and I think another 2kg weight saving per corner with the aluminium hats.
and that give an hige difference in term of stability and traction
and yes i upgraded in giro disc, i will do a first test in couple of week 👌🏻
#48
Some insights from my discussion with Manthey as Seb already mentioned, main goal is to get the 245 in front and 295 rear. There a couple of wheels which would work, the ones that Seb has, OZ has one as two OEM 718 wheels will also work. Regarding weight, I might only feel the difference while mounting the wheels to the car...
Pretty tough in the moment to find a car with bucket seats to start the project, there is almost no one available in my country.
#49
I also noticed your youtube name, "Sebastian Vittel" surely you're not the F1 driver?????
#51
#52
Hi all!
on the last week en the cayman gts accomplished 84 laps on the nordschleife with absolutely 0 problem except tires changing at 40laps (the trofeo r was already a bit used)
We can really say that this car is soooo strong 💪🏻
InTgr8r (09-16-2019)
#53
wow.... thats a lot!!!
I know how I felt after 4 Touristenfahrten laps, I cant imagine what +40 laps per day would be like.
Also, are you considering any engine tuning or are you concerned about extra stress on the motor.
#54
so then i will keep the oem power to save the original
warranty and honnestly the 360hp of the cayman gts is far enough for touristenfahrten 👌🏻
InTgr8r (09-17-2019)
#55
45 laps i a day! i was there this saturday but did only 5, testing a stage 2 tune on my boxter GTS.
Seems to work fine , it might help that i removed the cats , runns a little cooler i guess-
#56
40+ laps is just wow! The last track days I did roughly 18-20 laps and I felt that's enough..., so you did almost 1000km a day on the Ring and I know your speed, so just "Wahnsinn". Unfortunately I needed to cancel my participation on the 26th for the Manthey track day, but maybe I have a chance just to come along for an hour to see when you break the 1000km mark!
#58
Other than the KW suspension are other parts changed ? A arms, links, sway bars, etc ?
Cheers,
CH
Cheers,
CH
the car is one 718 gts european spec and the following setup was made by MANTHEY RACING:
-totally stock engine
-Complete KW competition 3 ways suspension with nordschleife setup and camber (around -3 front and -2.8 rear)
- cayman GT4 BBS FI forged wheel with tire size 295 rear and 245 front
-pirell trofeo R on BBS wheel and PS4s michelin on Oem wheels for rain use
-half roll cage
-schroth harness
-endless ma45 brake pads on oem steel disc
- brake line
-htc 64 brembo brake liquid
-TWL carbon ducktail (just for design no preformance expected)
-half roll cage
-schroth harness
- brake line
#59
but i think yes these parts was changed for more adjustment possibilities
#60
i made a test last week on the Nurburgring with snow tire on heavy rain.
it was not very the proper tire on the track except that for aquaplaning and cold condition they are perfect.
i sell the set of wheels with new michelin PA4 alpin on it
the dimension are Oem in 19’ 235 on front 265 rear
perfect for daily driving and winter.
i paied the full pack (including tpms sensor) 1600€
sold for 599€ if picked up at nurburgring
MP please
