Suncoast Project Car
#31
You've said this a couple of times now. I figured it was a typo the first time since running rich actually cools an engine. It's running lean that creates more heat. Would it be more accurate to say that the Cobb tune allows you to burn more fuel at the optimum mix to create more power, which in turn generates more engine heat?
borivojc (10-02-2023)
#32
Basic Sponsor
That makes sense to us (could be completely off target though, we're definitely not tuners by any stretch of the imagination). The tune uses a richer fuel mixture which picks up power, but with a lack of cooling we're thinking that in this case more power is generating more heat with no where for it to go. With COBB looking to address the cooling for their Stage 2 which creates even more power we think that would be the case here as well. But again, we may be way off here, this is just what we've experience so far.
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow our Project 718 Build Thread!
Stay connected:
Join Our Newsletter
Facebook
SuncoastParts.com
Stay connected:
Join Our Newsletter
#34
#35
Basic Sponsor
Some fresh images from 3 days at the track with PCA. The car didn't skip a beat the whole time. We might need to pick up a set of the Rennline grille inserts because we kept puling out pieces of rubber from the center radiator....
#36
Curious about the H&R PASM lowering springs you have on this. Do you have the sport springs or the VTF adjustable ones?
#37
Basic Sponsor
We went with the normal PASM lowering springs from H&R, not the adjustable fronts and they have been good to us so far. We had H&R on the last car we ran and never had an issue
#38
That’s a very nice project, congrat for it!
i have a similar project now based on my cayman 718 gts, Manthey racing will take care of it for all tha chassis parts and adjustment
i have a question about the rear wing, what is the top speed you already done with it? I would like to mount one but iam a bit afraid about the resistance in the time due to the very simple screw in system.
my car will be used only on the nurburgring with high speed and downforce all the time...
#39
Basic Sponsor
Thanks!! Good luck with your project!
The highest speed we've seen has been 142mph on the back straight at Sebring before braking for Turn 17. It has a lot of shake to it at that speed so we're exploring a way to reinforce it.
Here's two fresh photos from the Toys for Tots rally we hosted last weekend
#40
Maybe you would be better off with the Techart rear wing?
I notice it has an extra duck tail integrated into the design which distributes weight across the rear trunk lid and looks to tie everything in and make it more secure.
Maybe they also matched it better to the Techart front lip.
#41
Basic Sponsor
#42
Could you give any feedback on the two different tires? I'm trying to decide between them for a set of dedicated track tires and wheels. Thanks!
#43
Basic Sponsor
We got really comfortable with the RE-71R's while they were on. Great feedback and lasted 4 weekends for us. Once we switched to the Cup 2's we noticed an immediate rise in grip after the got a few heat cycles and they are a lot quieter, which is a good and bad thing. It did take us a few sessions to dial in the pressures and we felt they were the best at 28F/29R HOT which means 20F/21R COLD. We've only done a couple of days on them and we have two four-day events coming up in January at Sebring so we should be set for those. I think for a dedicated track car the Cup 2's are the way to go. If you do Auto-X and occasional track time then the RE-71R's might be a better.
#44
Thank you! Interesting observation on the heat cycles. I was wondering why the Tire Rack offers their heat cycling service for the Cup 2s but not the RE-71Rs--your experience may indicate that the RE-71Rs don't benefit as much from it.
#45
I saw APR tore apart a Cayman and 3d scanned in the whole engine package. Packaging is very tight.... they will be room for improving the radiators for the air-water IC system, but don't expect a ton of improvement as there's just very little extra space in there. For a dedicated track car, could ditch the A/C system and add an extra water radiator in place of the a/c condensor.
