20" stock rear wheels width
Looking at the info box for the 20" Carrera S IV alloy wheels on the configurator, when building a 718, reveals the following:
Most after market options I've come across, for 19" wheels, are 10-10.5" wide on the rears...
- 8.5 x 20 ET 49 with 245/35 ZR 20 tires (front)
- 11.5 x 20 ET 76 with 305/30 ZR 20 tires (rear)
I just purchased this baby and I think the images are high-enough resolution that you could tell from the pictures....
https://www.porscheofcoloradosprings...man-c-2415.htm
Yeah, looks like you have the 911 measurements.
This is what it says in the 718 catalogue for standard wheels:
Standard wheels Front: 8 J x 18 ET 57, Rear: 9.5 J x 18 ET 49, Front: 8 J x 19 ET 57, Rear: 10 J x 19 ET 45
Standard tyres Front: 235/45 ZR 18, Rear: 265/45 ZR 18, Front: 235/40 ZR 19, Rear: 265/40 ZR 19
718 GTS catalogue with 20" Carrera S wheels:
Standard wheels Front: 8 J x 20 ET 57, Rear: 10 J x 20 ET 45
Standard tyres Front: 235/35 ZR 20, Rear: 265/35 ZR 20
The optional 20" 911 Turbo Wheels or 20" Carrera Sport Wheels are: 8.5 J x 20 ET 57, Rear: 10.5 J x 20 ET 47.
So they aren't as wide as the configurator says (which uses the 911 dimensions), but they are wider than the Carrera S wheels that come standard on the GTS.
I did get the impression that the Carrera Sport wheels did have a slightly better stance. Although personally I'd probably go for GT4 wheels over the Carrera S if I was upgrading.
