356 Forum 1948-1965
Engine problem
Old Nov 19, 2003 | 02:19 AM
autowerks928's Avatar
autowerks928
6th Gear
Angry Engine problem
Hi I have a 356 c with a big bore kit on it 1750cc the engine has only done about 1800miles and has now developed a knock.I have pulled the engine down to the case and have found that three out of four pistons have picked up on the bore. It also looks as if the engine has ofer heated as the ends of the piston rings have turned blue.
I wondered if anyone has seen or heard of this before, as I dont want to put it back together again and have the same problem.
Old Nov 19, 2003 | 02:25 AM
hoffman912's Avatar
hoffman912
The Hoffinator
hmmmm.. if you wanna know suggestions tonight try 912bbs.org
and go to so cal or bay area board. i noticed some of the engine gurus are on tonight
Old Nov 19, 2003 | 01:51 PM
Steve Jensen's Avatar
Steve Jensen
Sign up to the 356talk listserv on www.356registry.org - lots of very knowledgeable folks on the list.
