356 Forum 1948-1965
Overheating
Old Jun 10, 2014 | 10:28 PM
1965356's Avatar
1965356
Default Overheating
Car suddenly started overheating. Well the gauge says it is . All the way to the red. Where to look first? Car was perfect the last week and then suddenly this
Old Jun 11, 2014 | 12:15 AM
doublecabmel's Avatar
doublecabmel
pretty odd I'd have to say. Check the mesh vent behind the tin- reach your hand over the top of the engine and you can feel it. sometimes that gets clogged. Also there could be a problem with the sending unit
Old Jun 11, 2014 | 07:21 AM
points's Avatar
points
I bought a dipstik-thermometer which was worth every penny of 40 bucks.
Then installed a aluminum oil cooler which changed everything. My 52 year old oil cooler had such dirty fins and was so fouled it was useless.
Old Jun 11, 2014 | 10:08 AM
dave292's Avatar
dave292
Is the fan belt still on? Could be that the oil cooler needs servicing. Did you check the oil level?
Old Jun 11, 2014 | 05:29 PM
1965356's Avatar
1965356
Thankseveryone,oil level good, new aluminum cooler fitted last year. It's gone to the shop to check but I think the gauge or sender is the problem
Old Jun 13, 2014 | 11:21 AM
dave292's Avatar
dave292
Can you let us know what the problem was?
Old Jun 13, 2014 | 02:54 PM
Carlo_Carrera's Avatar
Carlo_Carrera
Yes, a sudden change like that is gauge or sender or bad ground.
Old Jun 13, 2014 | 09:58 PM
1965356's Avatar
1965356
Seems like bad sender so waiting on new one. Dip stick thermometer shows engine running very cool so no problem
Old Jun 15, 2014 | 02:06 PM
dave292's Avatar
dave292
You might want to check out 356registry threads about senders if you have a 6V system.
Old Jul 7, 2014 | 04:22 PM
Steam Driver's Avatar
Steam Driver
The sender works (if memory serves me correctly) by adjusting the resistance to ground. So a sudden full-scale deflection would most likely indicate a faulty sender or that the wire to it has gone to ground someplace. Happened to me once in the 914-6. In that case the wire came off the sender and was bouncing around causing rapid full-scale deflections of the needle. Cured by reattaching the wire. Disconcerting when it first happens though.
