help id this number please
I have the following numbers off what is believed a 1958 356 engine and tranny can anyone tell me anything about it and what it would be worth??
engine numbers as follows 24381 with a 1600 on the other side of the case
then to the right of the dizzy 701
Tranny numbers 36 T 13 301103E
ah 27244
Any help would be appreciated. I am going to see if I can get this re aqainted with it Original car if it be true porsche
thanks
ah 27244
thanks
mb,
24381 is not an engine serial #. the best way to clarify the many #s stamped on a 356 motor is by their location. the engine serial # is located on the generator mounting stand, just above where "made in germany" is cast, facing the rear of the engine compartment.
if 24381 is on the case (facing upwards, on the left side of the split), then that is the case casting #. usually, the # to the right side of the split ids the engine type (616/1, 616/2, 616/7, etc.), & I seem to recall that occasionally the actual displacement is stamped there instead (1600), but I think that may be on engines installed in the 912 model (616/36 or /39), or for OEM replacement cases. I have a 356 1600 motor w/ 1600S stamped there.
I'm not familiar w/ the 701 #.
I believe 27244 is your tranny serial #. I can't recall the other sequence, but it may be an internal ZF # relating to type, build date &/or gearset.
I don't think I helped much, but if you wish to try to reintroduce that powertrain to its original chassis, the best place to offer it is the 356 registry, where it is much-appreciated and often successful for all parties. Best of luck!
http://www.356registry.org/tech/lookup.html
or post on the Talk List: http://www.356registry.org/356talk/join_or_leave.html
