Powered landing gear?
Old 01-18-2017, 06:58 PM
pmason
pmason's Avatar
Default Powered landing gear?
Just picked up my new 36ft Bravo gooseneck today and just cranking it once convinced me I need a powered landing gear. The good news is that its already set up for a hydraulic unit with a mounting plate in the center.
There seems to be 2 types electric and hydraulic, is there a preference? What do people have?
I so see some other kits also that just bolt on to the exiting landing gear.
Old 01-19-2017, 08:08 AM
Viperbob1
Viperbob1's Avatar
I have hydraulic. Much better than electric in my opinion
Old 01-19-2017, 09:20 AM
pmason
pmason's Avatar
Doing some researching I'm coming to the same conclusion, hydraulic is better.
Bob you remember the brand you have?
I found two so far, Bigfoot and Equalizer Systems.
Old 01-19-2017, 10:26 AM
pontifex4
pontifex4's Avatar
Nice trailer!
Old 01-19-2017, 12:55 PM
Viperbob1
Viperbob1's Avatar
I have to check on which system i have, but funny story. So leaving Summit Point last year I could feel the rear tire on truck was having an issue. It became severe and knew a blowout was about to happen. I pulled into a rest stop and instead of unhooking everything and jacking up the rear of the truck, i put a block under the jack and lifted the truck rear end up and tire off the ground. It was like a Nascar pitstop and I was underway in 15 total minutes.
Old 01-19-2017, 06:21 PM
jwasilko
jwasilko's Avatar
I've got hydraulic on our 44' stacker. It's good. Just be sure you have a way to recharge the battery that drives the hydraulic pump.
I've had mine go dead twice and having to hand-crank when I could have pressed a switch.
Old 01-20-2017, 11:51 AM
IPGJames
IPGJames's Avatar
I have Hydraulic and no issues...that is about as far as i can tell you to which is better, ha
(and yes Jwasilko) make sure that battery is charged....i keep a tender on mine when in storage and my generator charges it when it is in use at the track
Old 02-04-2017, 09:26 AM
pmason
pmason's Avatar
Just to follow up, I just ordered a EqualizerSystems AM/24 unit. This is the unit that Bravo installs if you order as part of your build.
http://equalizersystems.com/equalize...lic-systems-2/
Old 02-04-2017, 10:39 AM
bkovac
bkovac's Avatar
I have the Equalizer Systems on my 24' and love it. It's the envy of most in the paddock
Quick Reply: Powered landing gear?
